fuel pump wiring...
fuel pump wiring...
Postby celica_gtx » Wed May 21, 2008 5:29 am
did the swap, car runs fine..
but im just tired of havin my fuel pump jumped at
the diag. port..
wut have u guys done?
i have it runnin to a pilot switch now but id like
sumthing new... :shrug:
transformation has BEGUN!!!
90GT W/ 90 3SGTE/ SOLD
91 ALL-TRAC 215 w 205 swapd
10 Scion Xb-kid hauler
celica_gtx
Postby Carolina91GT-S » Wed May 21, 2008 9:31 pm
Have you tried it without the jumper. The way I did my swap wiring, the pump runs as normal. The fuel pump is part of the car/chassis wiring on your 5SFE powered car. It should run like normal, switched with the key and it's on.
Carolina91GT-S
Postby celica_gtx » Thu May 22, 2008 3:49 am
thats wut i wanna kind of do.
i just remember y i had it jumped
instead of wiring it that way..
i remember not having the wires for the harness or sumthing.
did the swap almost 4 yrs ago now so its been sum time.
celica_gtx
Postby Carolina91GT-S » Thu May 22, 2008 1:46 pm
The wries for the harness are already on your car, you have had it all along... Well, that is if your car was running with the 5SFE in it before you did the swap. Like I said the fuel pump circuit is part of the car, not part of the swap.
All that being said though. In order to help you. We need to know what year/model you have and what you have done with the wiring already. otherwise it could take a long time and a lot of guesses.
Carolina91GT-S
Postby celica_gtx » Sat May 24, 2008 8:59 pm
1990 gt w 93 3sgte
havent done any other type of wiring just wut need to be done to the swap....
celica_gtx
5sfe doesn't use a Fuel pump relay.
Postby TozeN » Mon May 26, 2008 1:15 am
The 5sfe doesn't use a fuel pump relay, the voltage comes from the opening circuit relay. On the 3sgte, the power goes from the ope3ning circuit relay to the fuel pump relay. And the ecu controls the fuel pump relay, it chooses the path throught the relay to either direct 12v to fuel pump or 12v to the resistor which resist the power going to the pump.
However the Fuel pump resistor, and the fuel pump relay are both in the engine bay of the all-trac/gt4 and your having a swapped fwd probably don t have it.
90 Celica GT, swapped jdm 3sgte SOLD
90 all trac, white #91, gt4RC swap.
92 all trac, red, SOLD
TozeN
Postby Carolina91GT-S » Mon May 26, 2008 3:29 am
"just the wiring that needs to be done for the swap" is not enough information. Tell us what wires you changed or otherwise connected to what points.
Tozen is correct. If your circuit opening relay is wired up correctly to your fuel pump circuit then it should be fine. All this is very vague though.... details about what you have already done would help us to help you. Which wires (ID'd by signal) did you connect to what pins on what connectors?
Carolina91GT-S
Return to FWD Celica
