mr2 tranny question!? figured it out
Postby celica_gtx » Sat May 24, 2008 9:04 pm
well i was gettin no help from celicatech...
maybe i can get more from here
well i have found a 95 mr2 trans
rebuilt w 500 miles on it!!!!!
w lsd..
my question....
how can u tell if it is in fact lsd?
is there a serial # i should look for..
i know on sum trans w lsd u can see straight through
the trans...
i dnt wanna get jipped!
thanks
also w the axles
y is it that i need to use alltrac outers?
are the GT to weak...?
i will be putting this on my 90 GT
or can u put me in the right direction
for a list of things needed
thanks to da guys at mr2 oc helpd me out
if u were wondering...
Pull out the axle, look inside the shaft, and you'll see a bar in the middle if it has a factory equipped LSD.
It was not on ALL 93+ E153 transmissions, but it was an option beginning in '93.
transformation has BEGUN!!!
90GT W/ 90 3SGTE/ SOLD
91 ALL-TRAC 215 w 205 swapd
10 Scion Xb-kid hauler
celica_gtx
Postby celicast184 » Thu Sep 11, 2008 8:11 am
the only way that you could tell, is if it has a bar inside the axle shaft. Being that, this is an mr2 turbo transmission, the bar would indicate lsd.
You have to use alltrac outter axles because the end of the outter axle connects to the inner axle with 6 bolts. GT axles on the other hand are two piece axles with the outter axle floating inside the inner axle with bearings. The other end that connects to the hub are made with the same amount of teeths to fit the GT hubs.
I <3 MY ST214
celicast184
Postby celicast184 » Thu Sep 11, 2008 8:16 am
off topic, did you ever get your fuel pump issue resolved? i read it over in celicatech a while back. if you haven't, it must be that your circuit opening relay is not turnning on.
I <3 MY ST214
celicast184
Postby celica_gtx » Fri Sep 12, 2008 5:49 pm
no..
it just runs balls out all day...
i kindof like havin it on a switch..
its funny when friends try to start my car
then die bc its not on them the worried look thinkin that
they broke it lookin all worried
lol
celica_gtx
Postby celicast184 » Mon Sep 15, 2008 4:44 pm
haha.. lolz.. well, if it works, then it works right? lolz.
I <3 MY ST214
celicast184
Return to FWD Celica
