electrical problem
electrical problem
Postby C.R.3.A.M » Fri Jun 27, 2008 5:44 pm
my problem is that on the igt pin of the ecu it keep flashing the ground even if my ignition key is off and i wonder if that could be cause by a wrong pinout cause i aint sure wich year is my harness and my ecm?????????????????????????????????????????????????????????????????????????
:D ty :D
:shoots: cream :shoots:
C.R.3.A.M
Postby Carolina91GT-S » Sun Aug 03, 2008 12:24 pm
what does "it keep flashing the ground" mean?
It might seem like a a lot to ask but if you can list what color wires are in what pins on your engine harness connectors for the ECU then I can tell you what year your harness is.
Also you should list your ECU part #
Carolina91GT-S
Return to FWD Celica
