3sge tranny starter getting in the way or turbo!
Postby MrMcQuacker » Tue Sep 09, 2008 8:49 pm
Hey guys im not sure what section this would go on because i have this on gt4 talk as well but someone kinda gave me some weird reply so imma try here. I have a 1986 Celica gts with a 3s ge motor. I am currently trying to swap a 93 2gen 3sgte which i see drops in. i understand that the wiring harness will change and thats about all i know. i have all the peices for the motor everything ecu harness sensors and etc. so after wiring all will plug n play. But the Starter on my tranny is getting in the way with the turbo motor. i saw someone say somethng about drilling new holes near the bell housing and turning it around. I need more help on Specifics on what that means. Also i want to know if there is a better way on avoiding such a job. Please help me. Pm me if you want. Ty
MrMcQuacker
Postby Dracov » Tue Sep 09, 2008 11:53 pm
On a 3S-GE tranny the starter is on the engine block side, which will interfere with the turbo/downpipe on a GTE motor. One way to solve this is get a starter from a non-GE (GTE or FE) and drill out a hole for it to fit on the transaxle side so it's out of the way, but if I remember right there might be problems lining it up with the flywheel's ring gear. You can't flip around your GE starter because it would then be spinning the wrong direction.
What would be easier so far as labor is concerned is to just get a tranny where the starter is pointed away from the engine block. But that would incur more costs for your swap, so the choice is up to you.
1988 Toyota Celica Alltrac
Dracov
Postby 3sgt-s » Wed Oct 08, 2008 7:56 pm
You can use a 5sfe tranny, v6 camry tranny, or tap the holes on your current tranny to make it work. I personally am using my 87 stock tranny and clutch and havent had a problem. Frankenstein but its all good.
Dees Nuts
3sgt-s
Postby 3sgt-s » Wed Oct 08, 2008 8:01 pm
If you use your stock tranny and you are getting a 2nd gen swap, you need to use your stock clutch with the 3sgte pressure plate and flywheel. Or get a custom order clutch assembly.
Dees Nuts
3sgt-s
Postby gtiac » Mon Nov 24, 2008 9:51 pm
3sgt-s wrote:If you use your stock tranny and you are getting a 2nd gen swap, you need to use your stock clutch with the 3sgte pressure plate and flywheel. Or get a custom order clutch assembly.
But you use the 3sge or an 3sgte starter??
gtiac
Postby MrMcQuacker » Mon Dec 15, 2008 8:10 am
3s gte starter
MrMcQuacker
Postby smc252 » Wed Jan 21, 2009 1:42 am
I did the 3s-gte swap in my 1986 GTS Celica, and ended up cutting a hole on the transmission, and tapped 2 holes to mount the starter on the opposite side.
Also, I DO have a v6 camry tranny up for sale, rebuilt.. You could simply just bolt everything together without modding shit.
-Steve
1988 All-Trac
(Rotting away, fiending for a tranny.)
1986 Celica GTS
(GT3071R forced 3s-gte + autronic smc)
smc252
Postby MrMcQuacker » Wed Jan 21, 2009 5:50 am
Does the V6 camry tranny fit the 3sgte?
MrMcQuacker
Postby celicast184 » Thu Jan 22, 2009 3:11 am
MrMcQuacker wrote:Does the V6 camry tranny fit the 3sgte?
yes, will bolt up with no problems. But, you need new transmission mount, which would be the rear mount only.
I <3 MY ST214
celicast184
Return to FWD Celica
