3S-FE engine question
Postby Wolf_Tm250 » Tue Dec 09, 2008 3:46 pm
Hi All,
as far as you know, is the 3S-FE engine compatible with 3S-GTE gearbox ?
TIA...
Wolf_Tm250
Gt-Four ST205 [2.34kg/hp DynoDynamics]
http://www.youtube.com/WolfTm250
DynoJet whp are false, and closer to other dynos FW hp. Please specify what dyno are your Whp from.
http://www.factorypro.com/magazine/dynojet_dyno_inflated_hp_reason.html
Wolf_Tm250
Postby mx6er2587 » Tue Dec 09, 2008 5:50 pm
which 3sgte gearbox? 4wd or the mr2 box?
mx6er2587
Postby Wolf_Tm250 » Tue Dec 09, 2008 7:59 pm
mx6er2587 wrote:which 3sgte gearbox? 4wd or the mr2 box?
Sorry, I didn't think it was different ! :oops:
4wd...
Wolf_Tm250
Wolf_Tm250
Postby mx6er2587 » Tue Dec 09, 2008 8:16 pm
well going off the assumption that the 3sfe block is similar to the 5sfe block the answer is yes and no. Everything will bolt up but the transfer case interferes with the block. Nothing some grinding shouldn't fix though
mx6er2587
Postby Wolf_Tm250 » Wed Dec 10, 2008 6:26 am
ok, thanks a lot mx!
And what about putting a 3sgte engine on a 3sfe awd gearbox (old Rav4)? :-D
Wolf_Tm250
Wolf_Tm250
Postby RedCelicaTRD » Wed Dec 10, 2008 7:54 am
That way should be ok also. You looking for some gear ratio changes?
Postby Wolf_Tm250 » Wed Dec 10, 2008 9:34 am
RedCelicaTRD wrote:That way should be ok also. You looking for some gear ratio changes?
Perfect!
I think not... old Rav4 doesn't have lower gears, so probably is a must to keep the original ratios for an off road application..
Thanks!
Wolf_Tm250
Wolf_Tm250
Postby mx6er2587 » Wed Dec 10, 2008 8:02 pm
So wait whats the plan? off road rav 4 with a 3sgte or swaping the 3sg trans into something with a 3sf?
mx6er2587
Postby Wolf_Tm250 » Wed Dec 10, 2008 8:33 pm
mx6er2587 wrote:So wait whats the plan? off road rav 4 with a 3sgte or swaping the 3sg trans into something with a 3sf?
Off road RAV4 with 3SGTE engine in...
I just hope the 3sfe gearbox/transmission will be strong enough... :D
Wolf_Tm250
Wolf_Tm250
Postby mx6er2587 » Wed Dec 10, 2008 8:43 pm
sounds like a good time
mx6er2587
Postby Wolf_Tm250 » Thu Dec 11, 2008 12:18 pm
mx6er2587 wrote:sounds like a good time
I hope... :D :D :D
Wolf_Tm250
Wolf_Tm250
Return to FWD Celica
