5th gen. alltrac rotor/brake setup on a gt-s?
Postby pintoBC_3sgte » Fri Jan 09, 2009 6:10 pm
hey was wondering if you guys can help me out. I was wondering if rotors and brake/lines work/fit the same and fit the same on a gt-s.
-Jon
pintoBC_3sgte
Postby crhinard » Mon Jan 12, 2009 1:40 am
Are you considering a rear disc swap?
crhinard
Postby Denver_whiteST185 » Mon Jan 12, 2009 1:46 am
the front brakes should swap right over, but there isn't much of an increase with them though. you may need 15" or larger wheels, but im not sure. you will just use your stock brake lines. all you should need is the calipers and the new rotors.
^Ted^
Denver_whiteST185
Postby pintoBC_3sgte » Mon Jan 12, 2009 1:51 am
wanted to swap out the front rotors and calipers for bigger ones.
pintoBC_3sgte
Return to FWD Celica
