F**k....
Postby celicaGTS_T » Fri Mar 13, 2009 5:24 am
Dood, dont worry about it... ur doing me a favor
celicaGTS_T
Postby Rpz123isme » Fri Mar 13, 2009 5:58 am
what ever. anywho what kind of oil and filter do you want? or should we go after we check everything out? all you need is a breaker bar. no other tools? and a cap. well i will leave here around 10:30 i will call you when i get to circuit's old building........ this is a general question. what color silicone should we use on his oil pan?
Hesperia, CA
Rpz123isme
Postby celicaGTS_T » Fri Mar 13, 2009 6:00 am
Lets make all the runs after we know the damage... as for silicone, i have the stuff from toyota left over (the black shit). Sounds good.
celicaGTS_T
Postby Rpz123isme » Fri Mar 13, 2009 6:02 am
ok be expecting my call i dont know exectly where you live.
Hesperia, CA
Rpz123isme
Postby celicaGTS_T » Fri Mar 13, 2009 6:05 am
Awesome, its not far circuit shitty... like 10 minutes.
celicaGTS_T
Postby celicaGTS_T » Fri Mar 13, 2009 11:17 pm
Well, the engine is toast, all the plastic bits got sucked into the rest of the block... time for a new one. :(
celicaGTS_T
Postby Rpz123isme » Sat Mar 14, 2009 12:15 am
i hear you. that shit sux. well atleast we can clean every thing up when we do the swap.
Hesperia, CA
Rpz123isme
Postby celicaGTS_T » Sat Mar 14, 2009 12:24 am
Yea, make that bitch shine lol.. BTW my parental units have AAA towing too, in case its needed
celicaGTS_T
Postby Rpz123isme » Sat Mar 14, 2009 12:32 am
kool 100 mile :shrug: i have it if you don't.
i will be pissed if you sit on the net all night being how you bitched out on the springs~ even tho i drove down just to help and sat in rush hour traffic for some 60 odd miles. if you change your mind i will come and get you 8)
Hesperia, CA
Rpz123isme
Postby celicaGTS_T » Sat Mar 14, 2009 1:19 am
well bitch, all of my work is online fucker :P .... and yes it is the 100-mile coverage.
celicaGTS_T
Postby athousandleaves » Wed Apr 01, 2009 3:53 am
I'm surprised the chunk didn't just melt...
1992 Red GT-FOUR RC 626•1800
1992 White turbo4WD
athousandleaves
Postby celicaGTS_T » Wed Apr 01, 2009 5:06 am
it probably did.... we didnt find much in the oil pan (a couple bits), but i doubt celica's were ever meant to sound like a diesel truck
celicaGTS_T
Postby Rpz123isme » Wed Apr 01, 2009 6:08 am
damn if it sounded that bad then it is in all four bearings. we can tare it apart and see after we get the new motor.
Hesperia, CA
Rpz123isme
Postby celicaGTS_T » Wed Apr 01, 2009 6:32 am
well let me clarify... it sounded like a muffled diesel truck... definately noticeable compared to a normal celica
celicaGTS_T
Postby bridge47 » Sat Apr 04, 2009 7:58 pm
Any plastic sucked up is not your problem. It won't melt, not hot enough. Lack of oil most likely. If your oil pump pick-up screen was already partially clogged, then maybe that did it if pieces were small enough.
Facts are stubborn things.
bridge47
Return to FWD Celica
