Its that time (PICS R UP)
Postby celicaGTS_T » Tue Apr 14, 2009 6:45 am
Doing a swap on my GTS, ill post pics up as soon as its done. starting day 2 tomorrow... messiest shit ever lol
celicaGTS_T
Postby AvivB » Tue Apr 14, 2009 4:35 pm
I just finish swapping 3S-GE to 3S-GTE (RC JDM) engine in ST182...
Let me know if you need some info on that.
/Aviv
('92 ST182RC 1/1 :-) )
AvivB
Postby celicaGTS_T » Wed Apr 15, 2009 4:04 am
all the dirty works done, didnt go with either engine for the swap. thx for the gesture tho 8)
celicaGTS_T
Postby celicaGTS_T » Thu Apr 16, 2009 11:52 pm
pics of the swap... not in order (LOTS OF PICS)
5sfe --> 3sfe
5sfe thru the bottom (horrible idea)
theres that punk Rpz123isme...
3sfe thru the top
celicaGTS_T
Postby Rick89GTS » Fri Apr 17, 2009 12:09 am
celicaGTS_T wrote:...5sfe --> 3sfe...
Just so I'm clear, you took out the 5SFE and put in a 3SFE?
Rick89GTS
Postby celicaGTS_T » Fri Apr 17, 2009 12:29 am
correct.... 8)
celicaGTS_T
Postby klue » Fri Apr 17, 2009 4:02 am
from bad to worse
Postby celicaGTS_T » Fri Apr 17, 2009 4:20 am
And u have evidence to support ur opinion?? If u toss the 5sfe intake/ exhaust manifold, injectors, and ecu on the 3sfe, you increase the output of the engine.
Sorry im not jumping on the 3sgte band-wagon like others. No offense. But obtaining a 3sfe from a 96-97 jdm rav-4 is more cost effective for me. So if u wanna bash me and my swap cuz its something you wouldnt have chosen, so be it.
celicaGTS_T
Postby Rpz123isme » Sat Apr 18, 2009 5:01 am
Look to all the haters. a 140k 5s with rod knock is a slow motor. A 3s with a larger intake and larger exhaust and bigger injectors, with a better computer, and 40k is a lot faster. also the 3s is square bore * stroke. where the 5s is not. granet you might have 5lbs less torque with the 3s you have about 40-50 more hp with the this setup. ohhhh and the best part is it only cost 500 dolars from start to finish with a 6 month unlimited mile warranty where puttin another 5s would cost 1200 plus. with lame results. my 2 cents
If you think i am full of $hit. bring your fwd celica to the plate and race justin. I will pay for track time and give anyone with a stock 5sfe celica a thousand dollars if they win. 8)
Hesperia, CA
Rpz123isme
Postby pintoBC_3sgte » Sat Apr 18, 2009 11:00 pm
lol read bring your fwd celica and get a grand if u win.. but skipped over stock.. :p damn
pintoBC_3sgte
Postby celicaGTS_T » Thu Apr 23, 2009 12:59 am
All finished
celicaGTS_T
Postby UtahSleeper » Thu Apr 23, 2009 9:11 pm
So, you have a 3sfe for a rav4 in it now. Did you also swap the ecu from the Rav? Have you noticed a difference with this engine from when the 5s ran well?
UtahSleeper
Postby celicaGTS_T » Fri Apr 24, 2009 1:21 am
Im running the 5sfe ecu, harness, intake/ exhaust manifolds, and injectors. I mean, slapping 2.2 parts onto a 2.0 liter engine boosts power a bit and yes its noticeable... It pulls in 5th gear :D
celicaGTS_T
Postby Mafix » Fri Apr 24, 2009 12:58 pm
Rpz123isme wrote:Look to all the haters. a 140k 5s with rod knock is a slow motor. A 3s with a larger intake and larger exhaust and bigger injectors, with a better computer, and 40k is a lot faster. also the 3s is square bore * stroke. where the 5s is not. granet you might have 5lbs less torque with the 3s you have about 40-50 more hp with the this setup. ohhhh and the best part is it only cost 500 dolars from start to finish with a 6 month unlimited mile warranty where puttin another 5s would cost 1200 plus. with lame results. my 2 cents
i'm game. let me know whether or not to even bother filling the nitrous bottle.
edit: better yet, i'll fill it and he can put it in his car. might give him a glimpse of hope.
keep the grand though. i'd feel bad.
Postby Mafix » Fri Apr 24, 2009 1:00 pm
celicaGTS_T wrote:Im running the 5sfe ecu, harness, intake/ exhaust manifolds, and injectors. I mean, slapping 2.2 parts onto a 2.0 liter engine boosts power a bit and yes its noticeable... It pulls in 5th gear :D
very interesting. glad it's working for you.
Return to FWD Celica
