CT26 INTERNAL WASTEGATE
Postby REY1385 » Mon Aug 17, 2009 4:56 pm
HI ANYBODY KNOWS HOW TO SET MY TURBO TO 6 PSI I'M USING THIS TURBO FOR MY 5SFE.
HAS AN INTERNAL WASTEGATE BUT I DONT KNOW HOW TO USE
THANKS
REY1385
Postby masco » Mon Aug 17, 2009 7:49 pm
I believe the turbo is internally gated around 7 psi. I don't think you can lower the boost pressure unless you change the wastegate spring.
1990 Turbo4wd - 1990 Corolla GT-S - 2002 RX300
masco
Postby AvivB » Tue Aug 18, 2009 2:51 pm
CT26 original wastegate is build to keep 5psi.
The T-VIS bleed some air out to raise it to 7psi on 3rd and up gears.
Without messing with the wastegate internals, there is no way to adjust it.
/Aviv
('92 ST182RC 1/1 :-) )
AvivB
Return to FWD Celica
