5SFE PISTON NEED HELP
Postby REY1385 » Thu Jul 08, 2010 12:59 pm
Hi i mest up my car cuz i put a turbo on my 5sfe 2.2 celica gt 1992, worn ring piston, so i will lok for a rebuild engine but need help to upgrade to a forged piston kit and port the heads or look for swap to a 3sgte head.
Any idea please im not a mechanic
REY1385
Re: 5SFE PISTON NEED HELP
Postby darthripley » Sat Jul 10, 2010 3:59 pm
post over on celicatech there is a lot of info there regarding 5sfe pistons etc.
87 AW11 MR2 "Super 2" 4AGZE
99 SXV20 Camry "Maul" 5SFE
Female Moderator
darthripley
All Trac Goddess
Postby wantech » Sun Jan 02, 2011 5:59 pm
I have a complete smooth running 2.2 engine, you can hear it runs, in Houston Texas
wantech
Postby klue » Sun Jan 02, 2011 7:48 pm
Any of the big companies make good pistons for the 5sfe. it is 87mm bore stock so dont get a 3sgte pisont(86mm)
have your block checked out you may need to overbore to 87.5.
I have used ROSS, malhe, and weisco for the 5sfe with good results
Return to FWD Celica
