lift or boost?
lift or boost?
Postby Droptop93 » Thu Aug 26, 2010 5:25 am
well for the past few months well almost a year ive been set on getting a gen 3 or gen 4 3sgte. a couple of months ago i got to drive Austinc's 7th gen gts (2zz) and i gotta say lift is an amazing feeling. and reving to the sky is also fun. it got my thinking about the direction of my convertiable.
disclaimer: i know you all are biased ...hehehe
i have also been in a 2nd gen 3sgte swaped vert and a couple of alltracs. and boost is just as amazing when it comes on strong and hard.
Ive always had a sweet spot for the redtop BEAMS 3sge, and it being red(VC and intake) colorwise it wolud go perfect with my car. the only problem i run in to with this is with the BEAMS its pretty much drop in and go, not much as aftermarket power makers besides ITB's and maybe an exhaust header. where as with the GTE i could manipulate it to get to where i felt the power needed to be. (want to eventually own an Alltrac also)
ITs my DD in the nice weather months. both would go great in the car imo i just all of a sudden became undecided, i guess price will be the determing factor, not really looking for massive power just usable power and fun power for the highways cruizes and screwwing around in town. also something the honda guys wont expect out of a toyota.
idk thoughts?
Droptop93
Re: lift or boost?
Postby ___Scott___ » Fri Aug 27, 2010 2:15 am
V6 swap?
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Re: lift or boost?
Postby Droptop93 » Fri Aug 27, 2010 2:26 am
Negative...no v6 but its a good thought
Droptop93
Re: lift or boost?
Postby aus jd 2703 » Fri Aug 27, 2010 3:06 am
correct me if im wrong but arnt late model beams engines more expensive then 3sgte?
im sure u could do both lol run a lower compression beams engine on boost, i know an ae86 corolla in drift Australia was doing that
aus jd 2703
Re: lift or boost?
Postby Mafix » Tue Aug 31, 2010 11:56 am
boost > lift any day
lift has a limit when it stops working, you can always increase boost!
as for the beams motor:
get an aftermarket ems that can control the vvti. then add boost. then you have both.
disclaimer: holy expensive as hell, but well worth it in the end
Built Gen 1 3SGTE,Megan,Autopower,Forza,Precision,Haltech,COP,Racepak,FMIC,Nitto,CRW axles,Quaife,V6 trans,Competition Clutch,Fidanza,Moroso,ST,370whp,340tq
Sponsors: Midas, SRT, Paradise Racing, CRW, ST162.net
Re: lift or boost?
Postby mike325ci » Tue Aug 31, 2010 1:47 pm
i own both - a car with a 2zz (lift) and 3s (boost) and like them both in different ways. they are just different, so it's a matter of personal preference: so what do you really want? a nice-sounding high-revving motor? or ability to mod/upgrade power (fairly) easily? how much money and time do you have? a 2zz swap will take more work and money than a 3s, so it has a higher probability of you getting discouraged in the middle of it, running out of time, or running out of money.
:shrug:
NYC, NY, USA
Founder, Kabiela.com - Automotive Group Buying & Daily Deals
mike325ci
Re: lift or boost?
Postby WarTowels » Sun Sep 05, 2010 12:02 am
mike325ci wrote:i own both
Same.
I myself would sell the vert and buy an s2000 and an Alltrac. :P
I am pretty much done with FWD cars in general.
Lift is very fun, I very much enjoy it. And I also very much enjoy boost. The type of engine can really change the cars characteristics.
I haven't however, had the pleasure of driving or owning a car with both boost and lift which I hope to try out someday. When my S2K hits 100,000 I want to throw on a super charger, or possibly a disco potato.
If you are bent on putting a new engine in the vert, I'd opt for the Beams. Drop it in, get an exhaust and intake and leave it alone.
Leave the boost for an Alltrac.
Cheers,
-Towels
1993 All-trac
2003 S2000
WarTowels
Gold GTfour God
Re: lift or boost?
Postby mike325ci » Sun Sep 05, 2010 1:14 am
oh towels, what you said made me realize i need to correct what i said. i guess i lied: my 2zz is also supercharged, so it's boosted. when i think of "boost" i usually just think "turbocharged". but if boost = forced induction, then that would include supercharged as well, right? :P the car sounds incredible when fully wrung. although not as musical as 4ag, which i still miss once in a while...
NYC, NY, USA
mike325ci
Re: lift or boost?
Postby weapon5 » Tue Mar 22, 2011 10:05 am
heres my thought
3sgte = strong, cheap, but remember to do hg while is out. 5g can get you a 2.3 fully built engine from ats racing too
3sge beams = strong, expensive there is not much aftermarket support for this engine unless you have deep pockets and could custom parts
2zzge = glass engine, expensive. the swap alone going to be a pain. here are all the weakness, oil pump gear explode because they are weak as the oil pan have a bad baffle so during 1g the oil pick up doesn't work and draw air causing air bubbles that destroy the pump gear. the mmc liner in sleeve are great but once they are out of spec you got two option for the block, junk or re-sleeve. valve tend to drop as well. c60 tranny is a weak tranny as well, gear are tiny compare to a alltrac or mr2 tranny.
i own all three and know.
heres my suggestion. if you going to race your car alot 3sgte, if you dd and just want a unique appearance 3s beams, lift is good but not always ;D in the end is up to you. now if you get a yaris 2zzge will be fun in that :D
Meet up in the left lane.... :D
weapon5
Re: lift or boost?
Postby MrDB » Tue Mar 22, 2011 1:08 pm
have both
http://www.se7enmotorsports.co.uk/
Mabs is a top top bloke well respected and provides awesome kit.....
:D
MrDB
Return to FWD Celica
