Need help with Vac Line
Postby raygo » Mon Feb 20, 2012 1:01 am
hello everyone
I recently had a machanic work on my car, that I no longer wish to use. since he worked on my car noe the timing is off my a/c is not working and now I find this Vac line disconnected.
Can anyone tell me where it goes.
I have a 1990 GTS 5S-FE
Thanx
raygo
Re: Need help with Vac Line
Postby Dracov » Tue Feb 21, 2012 5:11 am
If I remember right that goes down to the power steering pump. There should be two such lines next to each other. Someone more versed in the 5S should correct me if I'm wrong
1988 Toyota Celica Alltrac
Dracov
Postby k.beaty » Wed Feb 22, 2012 11:57 pm
Dracov wrote:If I remember right that goes down to the power steering pump. There should be two such lines next to each other. Someone more versed in the 5S should correct me if I'm wrong
That particular line actually goes up to the cruise control unit.
Follow me on Instagram @kbt666
k.beaty
Return to FWD Celica
