Write up for converting AWD trans to FWD
Postby concealer404 » Fri Mar 09, 2012 6:22 pm
I know this was out there somewhere... anyone know where it is?
Also: Once this is done, will a limited slip that works in an E153 work in a converted trans?
Cars and stuff.
concealer404
Re: Write up for converting AWD trans to FWD
Postby WarTowels » Fri Mar 09, 2012 6:28 pm
Converting? Do you mean the switch that disconnects the rear?
I'm not sure anyone would actually convert an AWD transmission to FWD. Dear God, WHY?
It would require blocking off parts of the transmission or disabling parts. And you'd just end up a with a heavy fwd transmission when other FWD transmission are drop in.
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby concealer404 » Fri Mar 09, 2012 6:35 pm
WarTowels wrote:Converting? Do you mean the switch that disconnects the rear?
-Towels
It's been done... someone did it with an RC gearbox a few years back.
Think it would really be any heavier than an E153 anyways?
In this case, it's because i have an AWD transmission that nobody seems to want to pick up, nor want to actually pay shipping cost for, and i can't get an E153 until i sell said AWD transmission. I know it's possible to convert an AWD trans to FWD, so it seems like a somewhat logical conclusion at this point.
Cars and stuff.
concealer404
Postby CMS-GT4 » Fri Mar 09, 2012 6:36 pm
There is a whole thread on it on ctech. I think its linked in their swap faq.
Postby WarTowels » Fri Mar 09, 2012 9:04 pm
Well, I didn't say it was not possible... I said why would you want to, which is very different.
Purely speculation, but I can only assume that it would be heavier because it's inherently a more complicated design.
I'm not sure it is a logical conclusion, to me it's very illogical. It's more like a cheap solution to a problem. I understand working under a budget though. Sometimes you got to do what you got to do.
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby jonahs_3sgte » Fri Mar 09, 2012 9:22 pm
why not get 5th gen gts fwd transmission
its going to be lighter then the awd transmission
1988 ST165...66,000 miles
2009 Corolla
1999 Ranger
jonahs_3sgte
Postby concealer404 » Sat Mar 10, 2012 3:38 am
jonahs_3sgte wrote:why not get 5th gen gts fwd transmission
Because i already have one installed in my car, and the S53 will not hold up to the power i'm shooting for.
Cars and stuff.
concealer404
Postby concealer404 » Sat Mar 10, 2012 3:40 am
WarTowels wrote:Well, I didn't say it was not possible... I said why would you want to, which is very different.
-Towels
Wouldn't what makes it complicated (AWD) be removed? I need to check out the thread. :)
It's not really a budget thing, more of a space issue. I have ummm... 5 motors and 4 transmissions sitting behind my current project in my garage. Everything from a 2jz and an R154 to a Mazda BP and G25MR transmission. It's ugly. :shock:
Cars and stuff.
concealer404
Postby underscore » Sat Mar 10, 2012 2:11 pm
I remember reading something on Celicatech about just needing an MR2 or FWD Celica diff? In which case you could just snag an aftermarket MR2 diff and be good to go.
Postby concealer404 » Mon Mar 12, 2012 3:18 pm
underscore wrote:I remember reading something on Celicatech about just needing an MR2 or FWD Celica diff? In which case you could just snag an aftermarket MR2 diff and be good to go.
I have a TRD LSD for E153 already. :)
Cars and stuff.
concealer404
Postby l0ch0w » Mon Mar 12, 2012 4:05 pm
I believe that the only problem people have ever run into is when they want to convert an E15xF to run in an MR2.
Its totally possible to convert an E15xF to work in a FWD swap, you just have to have a donor E153 laying around, for the front diff cover and half shafts...
Andrew
1991 Red Alltrac
l0ch0w
Postby phattyduck » Mon Mar 12, 2012 5:08 pm
Exactly. The transfer case gets un-bolted, so all those parts are gone.
The front/center diff assembly needs to be replaced with a FWD diff, and requires a complete dis-assembly of the transmission, sadly. Find a cheap MR2 E153 to get the parts from and put it all together. You will also need MR2 turbo stub axles and the center support bearing - you can use Alltrac outer axles or '88-'91 Camry V6 / ES250 outer axles.
I used a Kaaz diff and converted an ST205 trans to an E153 in my FWD 3s-gte Camry and it worked great. The only problem I ever had was breaking axles. :D
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby ssj3timy » Wed Oct 10, 2012 9:34 pm
Hi, I bought a ST215 manual awd gear box and was wandering if It is possible to convert it to fwd as the gt4 boxes. I broke my beams S54 gearbox on a hard launch.
ssj3timy
Postby Zseme39 » Wed Oct 10, 2012 11:59 pm
DON'T DO IT! GET A FWD AND SELL ME YOUR AWD :D
Zseme39
1999 Mitsubishi Galant
Postby ssj3timy » Thu Oct 11, 2012 12:19 am
I would be more than happy buying a E153 or E56 but the only boxes I found in my country are the ones that came in the imported engines. thats why my ST184 needs another trans.
ssj3timy
Return to FWD Celica
