Just thought id share my V6 6th gen
Postby Smaay » Tue Oct 23, 2012 2:56 pm
ok took some pics
[url]="http://www.youtube.com/watch?v=Rk0XhQXD1o4&feature=youtu.be"]http://www.youtube.com/watch?v=Rk0XhQXD1o4...eature=youtu.be[/url]
2001 Celica GT-S 2ZZ-GTE
90 Celica All-Trac 3S-GTE
97 Supra 2JZ-GTE
97 Celica GT 3MZ/1MZ hybrid
Smaay
Re: Just thought id share my V6 6th gen
Postby Hotrodhendrix » Tue Oct 23, 2012 4:02 pm
clean example. very nice
Postby CMS-GT4 » Tue Oct 23, 2012 5:40 pm
Cool. Any plans beyond what you have done? Looks clean.
Postby Awesome-Trac » Tue Oct 23, 2012 6:16 pm
Now that's a awesome 6th Gen
•Daniel
Awesome-Trac
Postby Smaay » Thu Oct 25, 2012 3:59 am
oh yeah, this is a hybrid 3MZ block with 1MZ heads and electronics. with this setup i should get past the CA BAR to make it a legal swap. once i get the certificate, ill swap in a full 3MZ with a 1MZ VVT intake manifold and dual throttle body and electronics. the VVT 1MZ is still a cable not DBW and it will run the engine no problem.
97 Supra 2JZ-GTE
Smaay
Postby underscore » Thu Oct 25, 2012 1:06 pm
^ I was gonna ask why you went with 1M stuff on a 3MZ bottom end as everything I found says that the 3MZ makes more power and has a larger TB. So the 3MZ is DBW I assume?
Postby jaydog82 » Thu Oct 25, 2012 2:21 pm
Cool swap
jaydog82
Postby Smaay » Fri Oct 26, 2012 9:26 pm
underscore wrote:^ I was gonna ask why you went with 1M stuff on a 3MZ bottom end as everything I found says that the 3MZ makes more power and has a larger TB. So the 3MZ is DBW I assume?
a few reasons. yes the 3MZ is a DWB. but the main reason is to be a legal swap in California. you can only do a swap in a 5 speed that was originally a 5 speed, so leagaly only a full 1MZ (non VVT) is allowed. however because the 3MZ bottom end will work with the 1MZ heads, im sneaking in the extra .3 displacement.
97 Supra 2JZ-GTE
Smaay
Postby underscore » Sat Oct 27, 2012 12:00 am
Ok gotcha, so I could run a full 3MZ without too much hassle. Did the 3 only come on autos or something?
Postby CSAlltrac » Sat Oct 27, 2012 1:51 am
That's awesome dude. Way to build a bad ass car while remaining legal, that's a tough feat in Cali.
Postby polm » Wed Nov 07, 2012 3:34 am
Nice garage! (and cars!)
polm
Postby Smaay » Sat Dec 15, 2012 4:15 pm
underscore wrote:Ok gotcha, so I could run a full 3MZ without too much hassle. Did the 3 only come on autos or something?
yes the 3MZ only came mated to autos. now i did see one of the MR2 guys made an adapter plate and mated a larger TB on the 3MZ intake manifold. its the black plastic manifold but its lighter, less likely for heat soak, and larger runners. then he ran it with 1MZ VVT electronics. Still had to fight auto codes but no DBW issues
97 Supra 2JZ-GTE
Smaay
Postby underscore » Sun Dec 16, 2012 6:05 am
That's pretty cool, I'll likely be doing this in a year or so.
Postby Cuttyman9 » Mon May 29, 2017 1:18 am
Working on a 2gr swap myself.
Looks good!
1992 Celica GT Hatch
1971 Cutlass
1967 Chevelle
1975 Trans Am
1966 C20 Long Bed
1999 F150
Cuttyman9
Postby ___Scott___ » Mon May 29, 2017 12:46 pm
Cuttyman9 wrote:Working on a 2gr swap myself.
Looks good!
We're going to need build thread! :D
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Return to FWD Celica
