'90 Celica GT 5SFE Oil Pan Interchangeability Question
Postby Street_Chally73 » Sat Aug 24, 2013 2:31 am
Hey guys,
I am in need of a good, replacement oil pan to replace my existing one that was damaged by a PO's mechanic.
Anyways, does anyone happen to know if the pan from a '94 Camry LE is identical to the one used in a '90 Celica GT?
They have their oil pick-up tubes on the same side, correct?
I need to fix this issue soon 'cause I'm dripping oil out quickly.
Thanks all!
Street_Chally73
Re: '90 Celica GT 5SFE Oil Pan Interchangeability Question
Postby jaydog82 » Sat Aug 24, 2013 3:39 am
It might be different, I might have a good 90 gt oil pan around. I can check on Sunday. Why do you think the pan is bad?
jaydog82
Postby Street_Chally73 » Sat Aug 24, 2013 4:03 am
The shop that always did the guy's oil changes stripped the hell out of the oil plug hole's threads. I'd be pulling the pan to Helicoil it, so at that point I'd rather just replace the pan with a good one that doesn't have stripped out threads in that bung.
If you could check & get back to me on the condition of yours, that would be great! Thanks.!
Street_Chally73
Postby celicast184 » Sat Aug 24, 2013 12:53 pm
i also have one too.. lmk if u want it.
I <3 MY ST214
celicast184
Postby Street_Chally73 » Sat Aug 24, 2013 8:59 pm
celicast184 wrote:i also have one too.. lmk if u want it.
Awesome! I'll let you know if I will still need one once the other guy gets a chance to check out his tomorrow.
Thanks for the responses, guys! I kinda figured someone probably had a couple laying around, but figured I'd check to see if anyone knew if the '92+ Camry LE ones would fit.
Street_Chally73
Postby underscore » Sat Aug 24, 2013 10:56 pm
The 94 doesn't have the same part number but it may bolt up, I'm not sure. Here's everything that has the same part # for the oil pan:
01/1990-05/1995 TOYOTA MR2 SW20,21 11-05: CYLINDER BLOCK
Model Dates: Matching Models: Model Options: Links to diagrams:
01/1990-12/1991 SW21L-ACMZKA USA, CP, 5SFE, HTWC, MTM, 5F 11-05
01/1992-10/1993 SW21L-ACPZKA USA, CP, 5SFE, HTWC, ATM, 4FC 11-05
01/1990-12/1991 SW21L-AJMZKA USA, TBR, 5SFE, HTWC, MTM, 5F 11-05
01/1990-12/1991 SW21L-AJMZKK CND, TBR, 5SFE, HTWC, MTM, 5F 11-05
01/1990-12/1991 SW21L-AJPZKA USA, TBR, 5SFE, HTWC, ATM, 4FC 11-05
08/1987-07/1989 TOYOTA CELICA ST16* 11-05: CYLINDER BLOCK
08/1987-07/1989 ST162L-BCMSKA ST, USA, CP, 3SFE, MTM, 5F 11-05
01/1988-07/1989 ST162L-BCMSKK ST, CND, CP, 3SFE, MTM, 5F 11-05
08/1987-07/1989 ST162L-BCMVFA GTS, USA, CP, 3SGELC, MTM, 5F 11-05
08/1987-07/1989 ST162L-BCMVFK GTS, CND, CP, 3SGELC, MTM, 5F 11-05
08/1987-07/1989 ST162L-BCMVKA GT, USA, CP, 3SFE, MTM, 5F 11-05
01/1988-07/1989 ST162L-BCMVKK GT, CND, CP, 3SFE, MTM, 5F 11-05
08/1987-07/1989 ST162L-BCPSKA ST, USA, CP, 3SFE, ATM, 4FC 11-05
01/1988-07/1989 ST162L-BCPSKK ST, CND, CP, 3SFE, ATM, 4FC 11-05
08/1987-07/1989 ST162L-BCPVFA GTS, USA, CP, 3SGELC, ATM, 4FC 11-05
08/1987-07/1989 ST162L-BCPVKA GT, USA, CP, 3SFE, ATM, 4FC 11-05
08/1987-07/1989 ST162L-BCPVKK GT, CND, CP, 3SFE, ATM, 4FC 11-05
08/1987-07/1989 ST162L-BKMVKA GT, USA, CVT, 3SFE, MTM, 5F 11-05
08/1987-07/1989 ST162L-BKPVKA GT, USA, CVT, 3SFE, ATM, 4FC 11-05
08/1987-07/1989 ST162L-BLMVFA GTS, USA, LB, 3SGELC, MTM, 5F 11-05
08/1987-07/1989 ST162L-BLMVFK GTS, CND, LB, 3SGELC, MTM, 5F 11-05
08/1987-07/1989 ST162L-BLMVKA GT, USA, LB, 3SFE, MTM, 5F 11-05
08/1987-07/1989 ST162L-BLMVKK GT, CND, LB, 3SFE, MTM, 5F 11-05
08/1987-07/1989 ST162L-BLPVKA GT, USA, LB, 3SFE, ATM, 4FC 11-05
08/1987-07/1989 ST162L-BLPVKK GT, CND, LB, 3SFE, ATM, 4FC 11-05
09/1989-08/1993 TOYOTA CELICA AT180,ST18* 11-05: CYLINDER BLOCK
09/1989-07/1991 ST184L-BCMGKA GT, USA, CP, NOB, 5SFE, MTM 11-05
08/1991-08/1993 ST184L-BCMGKK GT, CND, CP, NOB, 5SFE, MTM 11-05
09/1989-07/1991 ST184L-BCPGKA GT, USA, CP, NOB, 5SFE, ATM 11-05
08/1991-08/1993 ST184L-BCPGKK GT, CND, CP, NOB, 5SFE, ATM 11-05
06/1990-08/1991 ST184L-BKMGKA GT, USA, CVT, NOB, 5SFE, MTM 11-05
06/1990-08/1991 ST184L-BKPGKA GT, USA, CVT, NOB, 5SFE, ATM 11-05
08/1991-08/1993 ST184L-BLMGKA GT, USA, LB, NOB, 5SFE, MTM 11-05
09/1989-07/1991 ST184L-BLMGKK GT, CND, LB, NOB, 5SFE, MTM 11-05
09/1989-07/1991 ST184L-BLMVKA GTS, USA, LB, WIB, 5SFE, MTM 11-05
08/1991-08/1993 ST184L-BLMVKK GTS, CND, LB, WIB, 5SFE, MTM 11-05
09/1989-07/1991 ST184L-BLPGKA GT, USA, LB, NOB, 5SFE, ATM 11-05
08/1991-08/1993 ST184L-BLPGKK GT, CND, LB, NOB, 5SFE, ATM 11-05
09/1989-07/1991 ST184L-BLPVKA GTS, USA, LB, WIB, 5SFE, ATM 11-05
08/1991-08/1993 ST184L-BLPVKK GTS, CND, LB, WIB, 5SFE, ATM 11-05
09/1993-07/1999 TOYOTA CELICA AT200,ST204 11-05: CYLINDER BLOCK
08/1995-11/1997 ST204L-BCMGKA GT, USA, CP, 5SFE, MTM 11-05
09/1993-07/1995 ST204L-BCMGKK GT, CND, CP, 5SFE, MTM 11-05
12/1997-07/1998 ST204L-BCMSKA ST, USA, CP, 5SFE, MTM 11-05
08/1995-11/1997 ST204L-BCPGKA GT, USA, CP, 5SFE, ATM 11-05
09/1993-07/1995 ST204L-BCPGKK GT, CND, CP, 5SFE, ATM 11-05
12/1997-07/1998 ST204L-BCPSKA ST, USA, CP, 5SFE, ATM 11-05
10/1995-04/1999 ST204L-BKMGKA GT, USA, CVT, 5SFE, MTM 11-05
10/1995-04/1999 ST204L-BKPGKA GT, USA, CVT, 5SFE, ATM 11-05
08/1995-11/1997 ST204L-BLMGKA GT, USA, LB, 5SFE, MTM 11-05
08/1995-07/1999 ST204L-BLMGKK GT, CND, LB, 5SFE, MTM 11-05
12/1997-07/1999 ST204L-BLMSKA ST, USA, LB, 5SFE, MTM 11-05
08/1995-11/1997 ST204L-BLPGKA GT, USA, LB, 5SFE, ATM 11-05
08/1995-07/1999 ST204L-BLPGKK GT, CND, LB, 5SFE, ATM 11-05
12/1997-07/1999 ST204L-BLPSKA ST, USA, LB, 5SFE, ATM 11-05
08/1988-05/1991 TOYOTA CAMRY SV2*,VZV21 11-05: CYLINDER BLOCK
08/1988-05/1991 SV21LG-UWMDKK DX, JPP, CND, WG, 3SFE, MTM, 5F 11-05
08/1988-05/1991 SV21LG-UWPDKA DX, JPP, USA, WG, 3SFE, ATM, 4FC 11-05
08/1988-05/1991 SV21LG-UWPDKK DX, JPP, CND, WG, 3SFE, ATM, 4FC 11-05
08/1988-05/1991 SV21LG-UWPNKK LE, JPP, CND, WG, 3SFE, ATM, 4FC 11-05
08/1988-05/1991 SV21L-UEMBKA STD, JPP, USA, SED, 3SFE, MTM, 5F 11-05
08/1988-05/1991 SV21L-UEMDKA DX, JPP, USA, SED, 3SFE, MTM, 5F 11-05
08/1988-05/1991 SV21L-UEMDKK DX, JPP, CND, SED, 3SFE, MTM, 5F 11-05
08/1988-05/1991 SV21L-UEMNKK LE, JPP, CND, SED, 3SFE, MTM, 5F 11-05
08/1988-05/1991 SV21L-UEPBKA STD, JPP, USA, SED, 3SFE, ATM, 4FC 11-05
08/1988-05/1991 SV21L-UEPDKA DX, JPP, USA, SED, 3SFE, ATM, 4FC 11-05
08/1988-05/1991 SV21L-UEPDKK DX, JPP, CND, SED, 3SFE, ATM, 4FC 11-05
08/1988-05/1991 SV21L-UEPNKA LE, JPP, USA, SED, 3SFE, ATM, 4FC 11-05
08/1988-05/1991 SV21L-UEPNKK LE, JPP, CND, SED, 3SFE, ATM, 4FC 11-05
08/1988-07/1990 SV25L-UEMDKA DX, JPP, USA, SED, 3SFE, MTM, 5F 11-05
08/1988-07/1990 SV25L-UEMDKK DX, JPP, CND, SED, 3SFE, MTM, 5F 11-05
08/1988-05/1991 SV25L-UEPDKA DX, JPP, USA, SED, 3SFE, ATM, 4FC 11-05
08/1988-05/1991 SV25L-UEPDKK DX, JPP, CND, SED, 3SFE, ATM, 4FC 11-05
08/1988-05/1991 SV25L-UEPNKA LE, JPP, USA, SED, 3SFE, ATM, 4FC 11-05
08/1988-05/1991 SV25L-UEPNKK LE, JPP, CND, SED, 3SFE, ATM, 4FC 11-05
07/1988-08/1991 TOYOTA CAMRY SV2*,VZV21 11-05: CYLINDER BLOCK
07/1988-08/1991 SV21L-AEMBKA STD, NAP, USA, SED, 3SFE, MTM, 5F 11-05
07/1988-08/1991 SV21L-AEMDKA DX, NAP, USA, SED, 3SFE, MTM, 5F 11-05
07/1988-08/1991 SV21L-AEPBKA STD, NAP, USA, SED, 3SFE, ATM, 4FC 11-05
07/1988-08/1991 SV21L-AEPDKA DX, NAP, USA, SED, 3SFE, ATM, 4FC 11-05
07/1988-08/1991 SV21L-AEPNKA LE, NAP, USA, SED, 3SFE, ATM, 4FC 11-05
11/1995-07/2000 TOYOTA RAV4 SXA1* 11-05: CYLINDER BLOCK
12/1997-07/2000 SXA10L-AKMGKA TP, 3SFE, MTM, 2D 11-05
12/1997-07/2000 SXA10L-AKPGKA TP, 3SFE, ATM, 2D 11-05
11/1995-08/1997 SXA10L-AZMGKA HT, 3SFE, MTM, 2D 11-05
11/1995-08/1997 SXA11L-AWMGKA HT, 3SFE, MTM, 4D 11-05
11/1995-08/1997 SXA11L-AWPGKA HT, 3SFE, ATM, 4D 11-05
12/1997-07/2000 SXA15L-AKMGKA TP, 3SFE, MTM, 2D 11-05
12/1997-07/2000 SXA15L-AKPGKA TP, 3SFE, ATM, 2D 11-05
02/1996-08/1997 SXA15L-AZMGKA HT, 3SFE, MTM, 2D 11-05
02/1996-08/1997 SXA15L-AZPGKA HT, 3SFE, ATM, 2D 11-05
02/1996-08/1997 SXA16L-AWMGKA HT, 3SFE, MTM, 4D 11-05
02/1996-08/1997 SXA16L-AWPGKA HT, 3SFE, ATM, 4D 11-05
Postby Street_Chally73 » Sat Aug 24, 2013 11:35 pm
Thanks for the complete interchange chart! I knew about those for sure being identical, but was trying to piece together why the later model I-4 Camrys weren't shown as being on that comprehensive list.
Either way, it looks like two guys on here could get me an exact fit pan, so I'll follow up on those & bypass my original inquiry.
Street_Chally73
Postby Street_Chally73 » Sun Aug 25, 2013 10:38 pm
Jaydog82, any news on possibly having a good spare one laying around?
If not, I can always go with Celicast184's offer.
I'll send a PM off to both of you.
Street_Chally73
Postby k.beaty » Tue Aug 27, 2013 1:45 pm
The Camry oil pan will not fit on the Celica. The Camry has balance shafts, whereas the Celica does not. This causes the oil pan to sit lower, and will hit the North/South cross member on the Celica.
Follow me on Instagram @kbt666
k.beaty
Postby quieter » Tue Aug 27, 2013 3:29 pm
ask that mechanic to reflare the thread on his own time lol, i would be pissed if i was you
2011 BMW 535xi M pack (daily)
-Simon
quieter
Postby Street_Chally73 » Tue Sep 03, 2013 2:36 am
^Unfortunately, it happened when the last owner had the car & he never knew that the leak was actually the stripped out oil plug (or that his mechanic was the reason for the leak). :/
Street_Chally73
Postby Street_Chally73 » Fri Sep 06, 2013 9:58 pm
TTT
Street_Chally73
Postby k.beaty » Fri Sep 06, 2013 10:24 pm
What's your issue? I thought I answered the question in your original post.
k.beaty
Postby Street_Chally73 » Fri Sep 27, 2013 6:12 am
I got a pan from CelicaST184 that should work. Thanks again!! :smokes:
Street_Chally73
Postby jaydog82 » Sun Sep 29, 2013 3:20 am
Sorry I never got back to you man, my life is crazy right now
jaydog82
Return to FWD Celica
