Interested in 3SGTE Swap
Postby AxelNavaja » Wed Nov 27, 2013 1:51 pm
Interested in 3SGTE Swap.... How reliable is it? How cost effective and what are the gains and losses of this swap. Just gathering information right now.
-1991 ST184 HatchBack
Keeping Her Alive One Part at a Time.
AxelNavaja
Re: Interested in 3SGTE Swap
Postby celica_gtx » Wed Nov 27, 2013 3:14 pm
Ctech has more info on swaps. But I've been running mine for 8yrs w no probs. Change the trans if u can. I ran the s54 for years n was limiting myself. It just depends how fast u wanna go.u can look close to 1500-2000 just to get the motor then put in and get it running. That's if u do the work ur self and all the wiring.
transformation has BEGUN!!!
90GT W/ 90 3SGTE/ SOLD
91 ALL-TRAC 215 w 205 swapd
10 Scion Xb-kid hauler
celica_gtx
Postby AxelNavaja » Wed Nov 27, 2013 4:34 pm
Wiring = NIGHTMARE for me. LOL The rest of the labor Im not worried but that wiring,,, shiiiiiet! LOL!
AxelNavaja
Postby fussellbug » Wed Nov 27, 2013 5:44 pm
There are a couple of guys that can make a custom engine harness for your swap that will be simple plug and play for you. It will cost less if you provide your old engine harness and the one from your newer engine so the connectors can be re-used, but it's still several hundred dollars. Forum member MR220V http://www.alltrac.net/phpBB2/memberlist.php?mode=viewprofile&u=9383 is well known on the MR2 forums for his harness work at reasonable prices and Dr. Tweak http://www.tweakdperformance.com/index2.html has made harnesses for almost very possible Toyota swap.
fussellbug
Images: 36
Postby AxelNavaja » Wed Nov 27, 2013 6:19 pm
Nice! Thats good to know.
AxelNavaja
Postby AxelNavaja » Wed Nov 27, 2013 6:28 pm
Also, Is trhis possible to do w/o loosing the AC? Im assuming it is but it never hurts to confirm.
AxelNavaja
Postby underscore » Wed Nov 27, 2013 6:56 pm
I don't see why it wouldn't be
Postby GT-Steezy » Thu Nov 28, 2013 2:14 am
You will read this and hear this again and again. BUY A FRONT CLIP. I wish I would have went that route, but I'm close to being done accumulating parts and ready to turn wrenches to get it started. But in all sincerity, front clip is the way to go. you get a few things to sell or save. All your sensors and other things are there, and you get a good reference point. Hope it all goes good for you, and would love to see another fwd 3sgte lurking around here.
GT-Steezy
Postby celica_gtx » Thu Nov 28, 2013 3:24 am
Clips are the way to go. I was sourcing parts last min and digging thro junk yards. I'd do that next time around n get dr. Tweaks harness. Or save up n get a alltrac. Its what ever YOU want
As long as ur happy dude.
celica_gtx
Postby AxelNavaja » Tue Dec 03, 2013 12:20 pm
Huh... Front clip...? Ok. I figured it was the easiest route. The main thing Im concerned with is tranny pairing. I have heard that the MR tranny might be a good option and also the rare 5 speed off a camry.... any suggestions?
AxelNavaja
Postby CTechBlueDragon » Tue Dec 03, 2013 1:09 pm
Unless your planning on finding an LSD trans to handle more power your stock trans will work fine... honestly get on over at celicatech.com There are tons of swaps on there, I actually just bought another GT to do a swap to!! Probably start a project thread for it this weekend and hopefully actually post things in it for once. lol
CTechBlueDragon
Images: 51
Postby AxelNavaja » Sun May 24, 2015 4:12 pm
Its been almost two years since I have posted but it finally is coming together. 3rd Gen 3SGTE with a E153. And I was lucky enough to come across a WRC motor.
More to follow.
AxelNavaja
Postby CTechBlueDragon » Mon May 25, 2015 12:24 pm
Good to hear you are still going for it. You should be happy as long as you get an lsd trans. I did just unswapped my 93GT w/caldina and sold the chassis because the stock trans without lsd made first and second gear very tricky to get any speed out of. I was looking at what I paid for the whole car just to get an LSD MR2 trans. I would NOT suggest anyone do the swap without a trans change, there is a good reason Toyota never threw the 3s into the FWD models, too much power. I am assuming some of that was it was too expensive to put LSD tranny into the mix for those at the price point they were aiming for also...
I opted to swap chassis instead.
Bought a 90 Camry Alltrac for 850 and sold the 93 GT chassis for 800.
A lot cheaper than buying an mr2 trans...
Swap is almost complete, still doing wiring and intercooler piping that's about it.
I hope you are happy with it, I had fun with mine but nothing beats AWD.
CTechBlueDragon
Images: 51
Postby AxelNavaja » Mon May 25, 2015 1:15 pm
Yes. I agree on the trans issue. Thats why I got in contact with one of the guys in the group and bought a FWD converted E153 with LSD. Managing that amount of power is important so between that, the suspension set up and some chassis bracing the car should handle the power and torque just fine. Not to mention that I have some very Celica savvy gents that are guiding me and helping me make this come together. And to my luck I got a hold of a WRC Motor. Nothing crazy but it is pretty cool. LOL!
AxelNavaja
Postby AxelNavaja » Thu Jun 18, 2015 1:54 am
So here is an update:
Bought a 3rd Gen 3sgte WRC motor. Motor was stripped down and had all seals redone with the exemption of the head gasket. The top mounted intercooler was replaced by a FMIC by Mishimoto. I ordered a plethora of parts from MR220V @ Prime Performance. We are going with a full 3" exhaust set up. The car is riding on Megan Racing Street Series Coilovers and 17x8 Drag DR-31 on all four corners with 35mm spacers in the rear. The wiring harness (along with the swap itself) is being done by Allen Wood in Wilde Lexus Sarasota.
I plan on stiffening the chassis when I get back next year and upgrade the CT turbine on the motor along with the ECU. It's a long slow process but it's coming together rather nicely.
AxelNavaja
Return to FWD Celica
