Switch to full style
Post a reply
Re: Interested in 3SGTE Swap
Fri Jul 17, 2015 3:39 pm
Ok, so after several years of toying with the idea of a 3SGTE here is step one: Removing the engine and getting the engine bay cleaned up .
As of right now...
Fri Jul 17, 2015 3:45 pm
We got extremely lucky and came a cross a 3rd Gen WRC 3SGTE. When I say lucky, I mean LUCKY! The shop I got it from must have sent me the wrong engine on accident and we didn't know until we received it. the Top mounted W-T-A intercooler was removed so we could see the anti lag ports. We have all the parts at the shop.
Fri Jul 17, 2015 3:46 pm
I also got my hands on a E153 FWD trans slightly build up. LOL
More to come later..... :D
Sun Nov 22, 2015 7:33 am
I have an LSD driverside axle stub if you need it! This is required to run the e153 LSD in our cars. Pm me
Sun Nov 22, 2015 6:51 pm
Thanks bud I'll keep it in mind. I know we have all the components already in the car. We are just waiting on ic plumbing and that should be pretty much it. I'm in Africa right now but my buddy is working on the car. When I get back it should be done and I'll post pictures of the process. Thanks again.
Thu Feb 18, 2016 1:12 pm
Renovating 90 wide body gts for a client.4th gen Caldina power,s54 for now.hows the cv joint ,camry combo go to use E150s Mosel trans,FWD?
Wed Jul 20, 2016 5:41 pm
JDMSD1 wrote:Renovating 90 wide body gts for a client.4th gen Caldina power,s54 for now.hows the cv joint ,camry combo go to use E150s Mosel trans,FWD?
So I was lucky enough to get my paws on an already built up E153. We used ST185/165 axles with camry inners.
Post a reply
