swap question
swap question
Postby 02bluerolla » Mon Oct 17, 2005 11:13 pm
ok ihave an st165 wad turbocelica 1988 and it has a blown moter and i was thinking........can i put an st185 engine on the car while still keeping the st165 tranny can this be done? and will i need the st185 ecu ?
help :cry:
02bluerolla
Postby 93celiconvertible » Wed Oct 19, 2005 5:18 am
i dont see why not the 165 trans will bolt the the 185 3s. i mean ive seen people put 1st gen st165 3sgtes using the s-53 (5th gen celica GT) transmission, the harness will be harder to work with...i have a 2nd gen st185 3sgte using the s-53 trans. all the ST-1** have the same bolt patterns for the transmissions correct me if im wrong...and i believe you will need a 185 ecu though....but try this website http://www.gtfour.ca/ i believe he has wiring conversions for putting 2nd gen 3sgtes into st165s
2nd gen jdm 3sgte swapped st-184
00 gpw ap1 stock
93celiconvertible
Postby 94st3sgte » Sat Jan 05, 2008 4:25 am
I def. recomend Doc tweak from phoneix tunning, I think his site is http://www.phoenixtuning.com, he did my buddies wiring harness, he said it was well worth every penny, and made it easy,
94st3sgte
Postby Gary » Sat Jan 05, 2008 4:43 am
94st3sgte wrote:I def. recomend Doc tweak from phoneix tunning, I think his site is http://www.phoenixtuning.com, he did my buddies wiring harness, he said it was well worth every penny, and made it easy,
What's up with Doc and you advertising for him?
Do you work for him?
Most of us know Doc but this is like 7th thread that you posted same thing over and over.
Some of these threads are over 2 year old. :shrug:
93 ST185
Gary
Postby 94st3sgte » Sat Jan 05, 2008 5:28 am
whoops my bad, i didn't see that they were old, no i don't work for him, he has help like a couple of my buddies out with wiring harness for their mr2 swaps, all my buddies really liked his finished product
94st3sgte
Return to FWD Celica
