how often do I need to bleed my stock brakes?
Postby QIK_GT4 » Wed Nov 23, 2005 10:17 am
I will be changing my brake pads soon and was wondering if I needed to bleed the brakes? the brake pedal feels good atm and if im doing a standard brake pad change would i have to bleed it? my friend reckons I you have to bleed emm everytime u change ur pads and im like WTF?
The Car:Black JDM 1990 ST185
The Mods: Whiteline Rear-sway-bar, K&N Panel, 3" Dump, HKS BOV, 2" Boost Gauge, Garret TMIC, TWM Short Shifter, Mirror Tints
QIK_GT4
Postby Cashback » Wed Nov 23, 2005 2:51 pm
you don't have to bleed them unless you have a leak or get air in the system
Cashback
Postby QIK_GT4 » Wed Nov 23, 2005 3:02 pm
thats what I told him! man the dudes a fool :lol:
coz i remember my mechanic didn't bleed nothing when he changed my brakes.. so now that i'm doing it my self i was just curious..
QIK_GT4
Postby TomsGT4 » Wed Nov 23, 2005 4:25 pm
You bleed your brakes is when you replace a caliper, change a line, if there's a leak, etc.
Tom
1990 ST185
1990 Corolla SR5
TomsGT4
Postby RIalltrac » Wed Nov 23, 2005 4:31 pm
I've also found that fluid that is extremely old once changed does make a difference. So if you think that the fluid in there is what came off the assembly line I would consider flushing the system, but at the moment is not neccessary to do.
Chris - 90 ST185
RIalltrac
Images: 2
Postby suprakid95 » Wed Nov 23, 2005 4:33 pm
your supposed to flush out the fluid every 2 years.
- Sney
suprakid95
Postby QIK_GT4 » Wed Nov 23, 2005 11:38 pm
is there a difference between bleeding them and flushing it all out? anyone have a write up of the proper procedure? my friend says u gotta do it in order form back to front? :shrug:
QIK_GT4
Postby suprakid95 » Thu Nov 24, 2005 3:29 am
yup you gota start with the one farthest away from the reservoir, then the one oppostie, just bleeding them is like flushing them. i think....
- Sney
suprakid95
Postby QIK_GT4 » Thu Nov 24, 2005 1:21 pm
ok heres the main question how do I COMPLETELY change the brake fluid over without getting air into the system and not mixing the two fluids? I SHOULDN'T drain the brake system dry right?
QIK_GT4
Postby TomsGT4 » Thu Nov 24, 2005 5:29 pm
To flush the system I just bleed out twice the capacity that the lines & resevoir hold (not sure what it exaclty is right now),
making sure to always top off the resevoir up front.
I do this from the rear driver side.
Then I bleed the other 3 corners as well in this order:
1. Rear Passenger
2. Front Driver
3. Front Passenger (with ABS).
Never let the resevoir go empty when topping it off.
I don't think it matters if it mixes in the process, because the ratio of old to new fluid when done is very small.
Oh yeah,
& don't re-use brake fluid that has been sitting on the shelf half-full for a long time.
There's a chance that the cap might not have been on tight & moisture got in.
I know some of you have a half full bottle sitting on the shelf of your garage right now.
So go on, get out there & throw it away :)
It's not expensive, just get a new bottle.
Also, careful taking off the bleeding-nut on the calipers.
Soak 'em good first.
They can break easy, especially if they are old.
I've done this once before.
Cursin' & throwing sh*t.
Tom
1990 ST185
1990 Corolla SR5
TomsGT4
Good to change.
Postby GMan » Thu Nov 24, 2005 11:31 pm
> QIK_GT4
> Location: Sydney, Australia
> Posted: Wed Nov 23, 2005 10:17 am
> Post subject: how often do I need to bleed my stock brakes?
No not 'need' to. Good to flush out the old though
occasionally.
Not a Bad idea. :-) Rather cheap insurance.
# TomsGT4
# Location: Windsor Ontario, Canada
# Posted: Thu Nov 24, 2005 5:29 pm
# Oh yeah,
# & don't re-use brake fluid that has been sitting on
# the shelf half-full for a long time.
All Very good advice. :-)
# There's a chance that the cap might not have been on
# tight & moisture got in.
The same thing happens In the car, Brake fluid can absorb some
moisture. It could lead to rusting the lines from the inside
over time.
Worth it to change the fluid when it starts to turn brown.
Which Might be after a year or two depending on how hard the
brakes are used ?
GMan
Postby esracing » Sat Dec 03, 2005 4:10 pm
bleed your brakes evry 10k or one year .i race toyotas and work for toyota .the more the better less problems with calipers failing.
esracing
Postby RedCelicaTRD » Sat Dec 03, 2005 4:21 pm
With Subarus we would do a gravity bleed every 30k. You would only add 1 qt of new fluid so it wasnt really a flush.
Postby Gurr » Wed Dec 07, 2005 10:25 pm
Okay why does everyone think that you bleed the rear passenger? because I KNOW FOR A FACT that you don't on the 165. You have to bleed the passenger front first. If you'd like an explanation on why. Look at the braking system diagrams with abs. You'll understand then. I believe it is the same on teh 185 but not completely positive.
Hope this helps.
White 165.
Working out the 2g head/turbo swap kinks right now. *hates wiring problems*
Gurr
Postby TomsGT4 » Thu Dec 08, 2005 4:36 pm
Isn't the 165's ABS actuator in the rear?
Tom
1990 ST185
1990 Corolla SR5
TomsGT4
Return to FAQ / Archive
