powerprimers
Postby alltracman78 » Thu Sep 23, 2004 8:00 pm
busdriver wrote:Kind of off the topic but I saw an '04 Duramax diesel with twin turbos and 81 lbs of boost that had a dyno sheet for 1300hp and 2100 lb-ft of torque :twisted: . He owns a diesel shop in Malta MT if you are ever in the area..
:shock: damn
81lbs of boost :shock:
The M1A1 tank has 1500hp and 4000 ft/lbs tq. :notworthy:
Postby illGT4 » Thu Sep 23, 2004 8:04 pm
Conrad_Turbo wrote:
CMS-GT4 wrote:That is what I thought. But how is it that tq can be higher then hp?
with 300hp, and 600 tq.
I know of several well tuned cars that produce higher tq then hp. One is a volvo, and it produces almost 100 more lbs of tq then hp.
Hp is derived from torque and rpms, if you have an engine with a lot of torque but can't rev very high then you'll get a very torqey motor with a low peak hp output. Another way to look at it is that you have an engine that is very efficient at a lower rpm than at high/redline rpms.
The WRC cars most likely have a very different hp and torque band than most street cars. Largely due to the restrictor and different design changes to work around that.
Yep Yep! Agreed! :)
Imagewww.illtuned.com
- Vehicle Dynamics Specialist
illGT4
Postby alltracman78 » Thu Sep 23, 2004 8:26 pm
Because they are measured at different RPM.
They aren't measured at different rpm, they just occur at different rpm.
Torque is of course the circular force the engine is producing. Max torque is when the engine is pumping air most effeciently, and hp is simply torque X rpm, so max hp is simply the point where the torque x rpm is the highest #. So you could theoretically have max t and hp at the same rpm. Never seen a engine that way tho :D
Postby alltracman78 » Thu Sep 23, 2004 8:39 pm
Gary wrote:Off topic too :wink:
Maximum power: 108,920 hp at 102 rpm
Maximum torque: 5,608,312 lb/ft at 102rpm
http://www.bath.ac.uk/~ccsshb/12cyl/
And here I eat my words.
An engine with max tq/hp at the same rpm
Postby illGT4 » Thu Sep 23, 2004 8:42 pm
<homer voice> mmmmmmmm... words..
That's one hell of an engine.. pretty heavy too. :)
illGT4
Postby alltracman78 » Thu Sep 23, 2004 8:45 pm
:D
yeah it is.
I've seen ones on Navy ships, but not that big or that good.
Postby shoteh » Thu Sep 23, 2004 10:52 pm
"Even at it's most efficient power setting, the big 14 consumes 1,660 gallons of heavy fuel oil per hour."....man i just got back from the gas station and it was $1.99 p/g...i would not want to fill that thing up...
"Some high-performance auto engines have a similar feature where an oil squirter nozzle squirts oil onto the bottom of the piston. " what engine has that?
shoteh
Postby illGT4 » Thu Sep 23, 2004 11:04 pm
shoteh wrote:"Some high-performance auto engines have a similar feature where an oil squirter nozzle squirts oil onto the bottom of the piston. "
Are you seriously asking? The 3S-GTE for one.
illGT4
Postby shoteh » Thu Sep 23, 2004 11:19 pm
does it really? sarcastically...
shoteh
Postby illGT4 » Thu Sep 23, 2004 11:31 pm
right...
Hence the reason I asked " Are you serious "
Pretty difficult to judge sarcasm on the internet buddy... I was trying to help, thinking you may not know. Have a nice day.
Peace
illGT4
Postby alltracman78 » Fri Sep 24, 2004 2:13 am
illGT4 wrote:right...
Peace
:D
Postby shoteh » Fri Sep 24, 2004 2:19 am
shoteh wrote:does it really? sarcastically...
maybe a emoticon will help :shrug: :smokes: (combine those two and you get sarcasm...
hey but thanks ill try to be less sarcastic next time... :)
shoteh
Postby alltracman78 » Fri Sep 24, 2004 5:05 am
shoteh wrote:"Even at it's most efficient power setting, the big 14 consumes 1,660 gallons of heavy fuel oil per hour."....man i just got back from the gas station and it was $1.99 p/g...i would not want to fill that thing up...
Maybe they get a volume discount :D
Postby d1alltrac » Thu Sep 30, 2004 8:07 pm
thats enought torque to stop the earth's rotation... :notworthy:
Patrick R.
88 ST165 x2
92 MR2 turbo
02 330i
d1alltrac
Postby illGT4 » Thu Sep 30, 2004 8:08 pm
ah shit.. someone's figured them out!!! RUN!
illGT4
Return to FAQ / Archive
