st165 to st185turbo/manifold OPTION 2 *updated*
• Page 2 of 3 • 1, 2, 3
Now did you need 2 SETS of 2 manifold gaskets...or just the 2 gaskets that make up 1 set?
'88 All-trac ST165
-Joel
- //Zee-Roh//
Can I use a felpro one of the mani-to-spacer side? I think they have felpro's in stock, and I already have 1 set of steel dealership gaskets...
'88 All-trac ST165
-Joel
- //Zee-Roh//
ok, I got to get in on this, I have a ST185 with a 1st gen 3SGTE and a second gen Turbo, with an ATA interheater. and my wastegate arm touches the bolt. it is fully closed, but it is actaually touching the bolt. So i don't know how luke has lots of clearing and others don't have any, and I mine works, but touches. I will get some pics tonight so we can compare.
- hacker_720
- Established Member
How the HECK did you guys get the dp off? I can't get the blace bolt that's holding it on next the one of the engine mounts...any tips? That's the only bolt left, and it's driving me CRAZY!!!
'88 All-trac ST165
-Joel
- //Zee-Roh//
//Zee-Roh// wrote:How the HECK did you guys get the dp off? I can't get the blace bolt that's holding it on next the one of the engine mounts...any tips? That's the only bolt left, and it's driving me CRAZY!!!
Liquid wrench, pb blaster, do you have a compressor and an impact wrench/gun? turn up the boost on the compressor
Patrick R.
88 ST165 x2
92 MR2 turbo
02 330i
88 ST165 x2
92 MR2 turbo
02 330i
d1alltrac - Established Member
Finally got it off, but damaged my PERFECT condition radiator in the process. I literally went made and ripped it off LOL.. Some pretty big fuckin' dents in it....I'm SOOOOOOOOO pissed off.
'88 All-trac ST165
-Joel
- //Zee-Roh//
- hacker_720
It's just the fact that the rad was in PERFECT condition before this...THAT'S what pisses me off the most.....
'88 All-trac ST165
-Joel
- //Zee-Roh//
reviving the thread but got a q...
so to run an aftermarket dp, such as one made for the st185... we must buy a spacer w/ extended studs to make it work?
or is there another way?
- jgdynamics
i didnt use any spacer in the end.... but i did try a spacer that was equal in thickness to the manifold spacer and it caused all kinds of clearence issues with the midpipe.... i just use the metal type gasket b/c its slightly thicker than the standard paper type and last alot longer. i am running an aussie d/p....
Red st165
White st165
Black st165 - finally gone.
2011 4DR Civic SI CBP
88st165 - Established Member
Bloody outstanding, I knew it could be done, have done the same thing, but have a wee oil leak that I see can be fixxed (off comes the turbo again....)
Thanks for helping this confused kiwi!
Go hard, or go home!
Arrive at the end of life sideways, well used and with a huge smile on your dial.
ST165. (project in my shed)
Holden ute... every day runner.
two feet, used when the cops got my licence...
- Rosco in New Zealand
- Newbie
Re: st165 to st185turbo/manifold OPTION 2 *updated*
i have the tubular manifold on my st165 and am also doing twin entry but what i find out to be easy and look good is getting braided oil feed and return lines along with adapter i found out about from another build, i would love to show you pictures but i havent done it completely yet.
"What Does All-Trac Mean?"
"...Kicks Ass!"
ST165 '88 All-Trac
ST204 '95 GT(under going ST205 conversion)<-on hold while i work on my ST165
'05 Scion TC
"...Kicks Ass!"
ST165 '88 All-Trac
'05 Scion TC
1Bryce1 - Club Member
