st165 to st185turbo/manifold OPTION 2 *updated*
Re: st165 to st185turbo/manifold OPTION 2 *updated*
Postby klue » Thu Jan 14, 2010 9:36 pm
I have got some flanges for the turbo if you need so you can use braided lines.
xiiimotorsports
st175
Postby monkey8oi » Thu Jan 14, 2010 10:11 pm
Just wanted to drop my 2 cents in.. I did the exact same thing in regards to the oil feed/return pipe with the bend.. Under boost pressure, that kink where the bend is has a good chance of bursting.. i was driving on my way to the tuner and under boost that bend on the oil feed/return pipe bursted open and needless to say i never made it to the tuner. Just FYI.. Another option instead of bending the hard lines is to cut the hard line and weld AN fittings to them and run steel braided hoses.. that's where i'm at now with it.
monkey8oi
Postby klue » Fri Jan 15, 2010 4:38 am
yea you have to have a good feel for the metal not to fatigue it to much.
I did end up machining a flange to use on the ct2X turbos
xiiimotorsports
st175
Postby monkey8oi » Fri Jan 15, 2010 4:30 pm
yeah, especially with that smaller oil line.. but it's hard to get it shaped the way you want without over kinking the metal. i ended up cutting and welding an fittings on the end of them. i didn't want to risk busting it again on the road. great write up nontheless tho..
monkey8oi
Postby klue » Fri Jan 15, 2010 5:55 pm
true, although I had my completely stock set up burst on the road that's why i went this route.
xiiimotorsports
st175
Postby 93cc » Sun Jun 05, 2011 9:20 pm
I have had the org. and a new supply line crack on me in the last two months... Anyone know of a kit with braided lines I can buy or instruction on to mod the stock one with braided lines.
93 Black AllTrac
81 Black/Blue Celica
2007 Silver Tacoma Sport
93cc
Postby klue » Mon Jun 06, 2011 3:54 am
I can make a kit for you, but I will need your measurements.
xiiimotorsports
st175
Postby monkey8oi » Mon Jun 06, 2011 6:21 pm
ebay also has a kit for this that comes with the steel braided lines.. after my second attempt to cut the hard lines and weld AN fittings to it, it still burst.. i ended up finding a kit on ebay for it that was pretty cheap.. still working as of now and i've had it on for a couple months now..
monkey8oi
Postby 93cc » Tue Jun 07, 2011 12:04 am
monkey8oi wrote:ebay also has a kit for this that comes with the steel braided lines.. after my second attempt to cut the hard lines and weld AN fittings to it, it still burst.. i ended up finding a kit on ebay for it that was pretty cheap.. still working as of now and i've had it on for a couple months now..
I saw the one on ebay but couldn't tell how it connected to the the block and oil pan.
what measurements would you need?
93 Black AllTrac
93cc
Postby klue » Tue Jun 07, 2011 4:34 pm
You can not weld the stock lines, to adapt them for use with AN fittings. My procedure is to braze them on, the lower temperature yields less stress on the part; thus no cracking issue. OEM equipment is brazed on, I have countless cars modified this way. No issues so far :)
Measurements would be the measurements of the lines you need in a length. Every kit is made to order, with countless turbo, position, options.
xiiimotorsports
st175
Return to FAQ / Archive
Users browsing this forum: Google Adsense [Bot] and 2 guests
