[FAQ] 3sge cam install write up
Postby tw2 » Tue Jun 20, 2006 7:43 pm
Yeah I wasn't sure whether the st162 had a 3sge or some 4A whatever motor like the pre 90 mr2. Apparently there is one company that does a drop in set of cams for gen 1. 264's only if I remember correctly. You may have to do some research.
Thomas, JDM 90 185, 06 350z
tw2
Postby Maloy » Tue Jun 20, 2006 8:50 pm
ats does the only 164s and iv heard that they arent that great of quality.
88 white st165 (stripped down on jack stands)
86 AE86 corolla gt-s coupe
Maloy
Postby tw2 » Mon Sep 11, 2006 7:39 am
Here are the gen 1 figures. So there is the same amount of gain in duration for gen 1 (162 into 165) as there is for those doing the gen 2 (182 into 185) swap. The difference is there is less gain in lift as compared to gen 2 when the swap is carried out.
ST162
IN Open/Close 5/55
EX Open/Close 55/5
Valve Lift 7.2/7.2
Degrees 240/240
ST165
IN Open/Close 4/48
EX Open/Close 48/4
Valve Lift 7.15/7.15
Degrees 232/232
tw2
Postby //Zee-Roh// » Mon Sep 11, 2006 4:41 pm
Damn I wanted at least a 244 angle...BAH Toda here I come I suppose.. unless I can find st162 cams for dirt to play with :lol:
Off I go to rip my turbo off. later doods
'88 All-trac ST165
-Joel
//Zee-Roh//
Postby killer_siller » Mon Sep 11, 2006 5:24 pm
i've got a set of ATS racing 264 cams for sale!
killer_siller
Re: [FAQ] 3sge cam install write up
Postby xander279 » Tue Jul 13, 2010 6:19 pm
do you have any overlap... are your exhaust and intake valves open simultaneously?
2013 Hyundai Genesis Coupe 2.0T
1992 Toyota Celica All-Trac Turbo
xander279
Postby dustinbart » Wed Oct 10, 2012 2:43 am
Bringing this back from the dead...
To make a long story short my cams where removed without being marked and I was wondering what the retard/advance was on 3sge cams on the gen1 head (st165).
Thanks!
88' st165-Gun metal (The build)
88' st165-Blue (DD)
86' Landcruiser FJ-60- Satin black (The Monster)
dustinbart
Postby celicast162v6swap » Wed Jul 22, 2015 3:17 am
IMHO I'm running a gen1 gte with gen1 ge cams both intake and exhaust. It is a really nice complement to my ge side feed intake. I can tell you that my intake cam is .006 inch bigger then the gte and the exhoust is .010 bigger. Another member mentioned to set my intake advance 1 tooth and exhaust retarded 1 tooth for more air in and exhaust out. I will see when I get adjustable cam gears if it makes a difference
88 celicaall-trac. New drag car project
87 celica gt-s once v6 turbo swapped and custom lights.
celicast162v6swap
Images: 9
Return to FAQ / Archive
