CS vs RC transmission oil cooler
Postby Conan » Fri Jun 09, 2006 9:49 am
Let it be known
The transmission oil cooler on the RC is different from the CS one - the RC cooler has 4 rows of cooling fins as opposed to 9 (!) in the CS model.
Conan
Postby CMS-GT4 » Fri Jun 09, 2006 12:35 pm
Any part numbers and prices for the CS one?
Postby Conan » Fri Jun 09, 2006 3:36 pm
CS (all years) 33490-20030
RC (08/1991 - 10/1991) 33490-20040
RC (10/1991 - 02/1992) 33490-20041
I'm not sure how the last two are different :shrug: bet the radiator is the same. The CS is $70 more in my EPC, all of them are expensive, and they come as an assembly (with lines and mounting stuff).
Conan
Postby Aracheon » Sat Jun 10, 2006 4:56 am
If you're buying a new 'OEM' one, wouldn't it just be cheaper to retrofit a larger, aftermarket one?
Chris
2009 STi
2008 Superduke
2009 DR-Z400S
2004 KLX 125
Aracheon
Postby Conan » Sat Jun 10, 2006 5:54 am
Aracheon wrote:If you're buying a new 'OEM' one, wouldn't it just be cheaper to retrofit a larger, aftermarket one?
Yes, it would ;)
Conan
Postby Conan » Sat Jun 10, 2006 9:31 am
GrpA (all years) 33490-20040 same as RC (08/1991 - 10/1991)
Conclusion:
CS > RC/GrpA :evil:
Conan
Return to FAQ / Archive
