Downpipe
Downpipe
Postby Traks » Sun Jul 23, 2006 12:11 am
Any write-ups on Downpipe (and exhuast) install? I am sure it is failry straight forward, but I really dont want to screw up. I am slowly getting more and more confident workign on my own car (mainly becuase I don't like other people workign on it :P). But I don't know if there is anything i should know before I go and install my new exhaust system (Aussie full)
Cheers
Topher.
1991 Aquamarine Alltrac ST185
Seattle, WA
Traks
Images: 4
Postby suprakid95 » Sun Jul 23, 2006 8:28 am
loosen bolts from exaust and turbo sides...pull off from turbo side first using the exuast as support then pull up carefully so you dont mess up the fins on the radiator. like you said pretty straight forward. you can also pull it straight down which ever you feel more comfortable with.
- Sney
suprakid95
Postby Traks » Wed Jul 26, 2006 4:24 am
If i was replace the whole exhaust system would it differ any?
Topher.
Seattle, WA
Traks
Images: 4
Postby TheAutoholic » Wed Jul 26, 2006 4:56 am
It just bolts to the turbo and the mid pipe. You can do it. 8)
Currently All Trac-less....
Dracov wrote:I'm firmly convinced GT-Four trannies are made from collapsed stars.
TheAutoholic
Postby d1alltrac » Wed Jul 26, 2006 5:44 am
i think with 185's you may have a hard time getting it by the oil filter or something like that (i dont have a 185 so im not sure what :P ) just do a search and im sure you'll find something, or someone with a 185 might chime in.
oh and if you were wondering about the rest of the exhaust that is pretty simple, just unbolt and bolt on the new stuff. you will have to unbolt the front crossmember then the midpipe just bolts right up and the rest is easy. if you are doing it by yourself jackstands are your best friend for holding the exhaust in place while you bolt it all up.
Patrick R.
88 ST165 x2
92 MR2 turbo
02 330i
d1alltrac
Postby SuperWhite92 » Wed Jul 26, 2006 5:51 am
Unbolt, Install, Rebolt.
Shaun
SuperWhite92
Postby Traks » Thu Jul 27, 2006 2:29 pm
Thanks guys, I am one of those peopel that gathers way too much knowledge before I go and do something. :) better safe than sorry, esp with my alltrac .
Last thing (that I can think of right now) The exhaust sealant that came with it goes in all the joints???
Topher.
Seattle, WA
Traks
Images: 4
Return to FAQ / Archive
