AIR INTAKE SYSTEM
AIR INTAKE SYSTEM
Postby 1992celica » Sat Aug 05, 2006 6:04 am
Does anyone know any sites where I can order an HKS super mega flow intake kit besides 935 motorsports?
1992celica
Postby Denver_whiteST185 » Sat Aug 05, 2006 5:18 pm
horsepower freaks, if its not under celica, check under the MR2 intakes.
^Ted^
Denver_whiteST185
Postby 1992celica » Thu Aug 31, 2006 5:18 pm
does a HKS intake kit made for an MR2 fit into the ST185?
1992celica
Postby syko says » Thu Aug 31, 2006 5:44 pm
do you mean this one???
Aloha,
Evan
syko says
Postby 1992celica » Thu Aug 31, 2006 5:57 pm
yea...but the MR2 is 200mm and the one made for the alltrac is 150mm. I just wanted to know if there is enough space b4 i open the package. The company sent me the wrong one....and I was wondering if i could work with it.
1992celica
Postby maxaud » Thu Aug 31, 2006 9:53 pm
here is the HKS one I had:
-Dustin
maxaud
Postby 1992celica » Thu Aug 31, 2006 10:04 pm
i definitely didn't get that one...they sent me the one that more flat but the diameter is a lot bigger.
1992celica
Postby maxaud » Thu Aug 31, 2006 10:11 pm
here is another closer look: click to make bigger (it may be an older model)
-Dustin
maxaud
Postby syko says » Fri Sep 01, 2006 12:06 am
the flat one that youre talking about probably wont fit.. the HKS ones that you see above are the ones that fit (in that particular way anyway) but my honeycomb cage got a dent because the screw connecting the vent to the hood hit it, otherwise it fits just right. the flat one probably will fit, just might have to route it a differnt way if your engine bay isnt stockish cluttered.
Aloha,
Evan
syko says
Postby 1992celica » Fri Sep 01, 2006 2:06 am
do you know of any sites that sell the kit...because HKS discontinued the model. So the shop i bought it from just started putting things together and giving me all the wrong pieces.
1992celica
Postby syko says » Fri Sep 01, 2006 3:02 am
i was searching around and i found this picture...
is this what your filter looks like? it does look a little bigger/flatter/wider.. maybe you could run a straight intake if you relocate your battery
Aloha,
Evan
syko says
Postby 1992celica » Fri Sep 01, 2006 4:57 am
yea mine definitely looks like that...i'm thinking of buying the right measurement one...becuz the one you have is 150mmx70mm i have 200mmx80mm. I'm gonna just customize it from there since they discontinued the model you have.
1992celica
Postby jlspec » Tue Sep 19, 2006 2:46 pm
I have the 80X200mm (new version) and it fits fine at the stock loaction. I'll try to get some pictures soon. Anyway, All that was needed is the Filter, adaptor, and bracket. It fits fine and sits just right before the vent.
jlspec
Postby 1992celica » Tue Sep 19, 2006 4:52 pm
did you have to relocate your battery?
1992celica
Postby jlspec » Tue Sep 19, 2006 5:12 pm
Nope, everything is where it should be.
jlspec
Return to FAQ / Archive
