Exhaust Installation Question
Postby Traks » Sun Aug 06, 2006 3:29 pm
I am installing an exhaust, DP Back, and with it came sealant that I am not sure where to put it. Is it at every junction, slip junctions only? Cat Junction? I dont know and I would rather ask and find out than mess it up.
Thanks in advance.
Topher.
1991 Aquamarine Alltrac ST185
Seattle, WA
Traks
Images: 4
Postby klue » Sun Aug 06, 2006 3:44 pm
the sealant shold be some sort of high temp RTV compound. Its what i use. Slap a good bit on each joining surface and let it cure via directions b4 u run the car. I got my aussie and used it on every gasket and mating surface because theyre supplied clapms and gaskets SUX.
Postby Traks » Sun Aug 13, 2006 4:20 am
Thank ya sir
Topher.
Seattle, WA
Traks
Images: 4
Return to FAQ / Archive
