trouble shooting stock boost gauge....
Postby 1992celica » Fri Sep 29, 2006 10:32 pm
Last night while driving home i noticed my stock boost gauge stop moving...what could be the problem? The needle moves when i start the car...but when im boosting it doesn't go anywhere. Anyone know what could be the problem?
1992celica
Postby Stubble » Sat Sep 30, 2006 12:33 am
You could have a problem with the Turbo Boost Sensor (mounted on the firewall), or with the wiring. I suspect that the former owner might have had a fuel cut defeat installed, and this is either messing with the signal or if he removed it, the wiring may not have been properly reattached.
I will also suggest that you don't bother worrying about the stock gauge. It really tells you nothing, is slow to react, and shouldn't be used to diagnose anything on your car. Get yourself an aftermarket gauge - any kind is better than the stock one.
Brady Ryall
1990 ST185 Red - parts
1990 ST185 Black
1999 Miata
2008 A3 Quattro S-line
Stubble
Postby //Zee-Roh// » Sat Sep 30, 2006 12:41 am
No doubt...ditch that POS boost gauge and get an aftermarket one. No use fixing something that doesn't even work well/right to begin with. Just my .02
'88 All-trac ST165
-Joel
//Zee-Roh//
Postby Gary » Sat Sep 30, 2006 1:59 am
First thing to check is to see if the vacuum line from the turbo pressure sensor came loose. Trace that back to the vacuum port on the left side of the manifold. (facing the car). But like everyone else said, get an aftermarket one ASAP.
93 ST185
Gary
Postby 1992celica » Sat Sep 30, 2006 4:09 am
which gauge is better mechanical or electrical.
1992celica
Postby Gary » Sat Sep 30, 2006 4:45 am
Not much difference. You'll have less risk of vacuum leak and easier to wire the electronic one. However, I have never seen anyone having leak on the mechanical gauge nor anyone complain about routing that nylon (or rubber) tube through the firewall. The mechanical is also cheaper. And unlike oil pressure gauge, if it ever leaks, it's just air coming out or being sucked in. No hot oil.
93 ST185
Gary
Postby //Zee-Roh// » Sat Sep 30, 2006 6:16 pm
My gauge start to finish took about 2 hrs with some pretty lame roadblocks (NPT fittings that worked etc.) It's not that cumbersome...and definately one of the best "mods" you can do for your car (in terms of safety). I bought my gauge at NAPA for 40 bucks cause my 20 dollar twos 'r' us one didn't work (grumble grumble grumble).
'88 All-trac ST165
-Joel
//Zee-Roh//
Return to FAQ / Archive
