The truth about ST215 3sgte engine
Re: The truth about ST215 3sgte engine
Postby JDMSD1 » Sun Jan 31, 2016 7:42 am
Hahaha,that's luxury.ive never had a project budget that allowed me to spend $500 on a custom harnass by someone else.sounds nice tho.
But the engine is too easy to start with a good relay fuse to the harnass 8 positive points and 2 negatives they run.id rather buy something else for my money.
JDMSD1
Postby UtahSleeper » Sun Jan 31, 2016 10:25 pm
JDMSD1 wrote:Hahaha,that's luxury.ive never had a project budget that allowed me to spend $500 on a custom harnass by someone else.sounds nice tho.
Guess it depends on where your experience is. I knew that if I tried to do the harness myself, even with instructions, I would have taken months to potentially finish it. Where as I can ship it off, work on other things, and simply install it. 400ish for a plug and play harness isn't bad in my eyes. Yes, I would have rather saved the money, but I hate having things taken apart and scattered for months or longer.
UtahSleeper
Postby JDMSD1 » Sun Jan 31, 2016 11:06 pm
That's why I have customers.
Wiring not so bad.
Everyone has their own way. Whatever works.
JDMSD1
Postby All-TracDreams » Tue May 24, 2016 10:26 pm
Can anyone shed some light on the little stickers found on the upper timing cover for the Gen 4s? The majority seem to be labeled "N2", but I have also seen "N3" (that also happen to be yellow?) and "N4" which are not uncommon. I feel like I may have even seen an "N5" once or twice, as well. Despite searching, the only 2 results that are even relevant have gone unanswered. I feel like it's some sort of manufacture date batch indicator, and/or perhaps denotes whether the engine came with a manual or automatic transmission attached from the factory. These hypotheses are due to the fact that the Gen 5 engines I've seen have had "N6" label stickers. Either way, any insight on this would be greatly appreciated!
Edit: "N5" sighting confirmed! (On a manual transmission Gen 4 motorset, and yellow)
Last edited by All-TracDreams on Fri May 27, 2016 1:02 am, edited 1 time in total.
All-TracDreams
Postby JDMSD1 » Thu May 26, 2016 4:02 am
I have seen N2 N4.
Interesting question.
N4 harnass is slightly different at 12 pin plug.
I've noticed.
JDMSD1
Postby abraxxa » Sat May 28, 2016 7:47 pm
Mine has a white N2 sticker and came from an automatic Caldina ST215.
And it had sleeves...
facelift ST205
abraxxa
Postby MWP » Sun May 29, 2016 2:14 am
abraxxa wrote:Mine has a white N2 sticker and came from an automatic Caldina ST215.
Sleeved bores?? From the factory? No way.
Postby JDMSD1 » Sun May 29, 2016 11:53 am
Sleeves?
JDMSD1
Postby Locker » Mon May 30, 2016 3:31 pm
I have an N2
90 ST185
Locker
Postby JDMSD1 » Mon May 30, 2016 4:12 pm
Me too N2.
So yours is sleeved?
JDMSD1
Postby Locker » Mon May 30, 2016 4:28 pm
JDMSD1 wrote:Me too N2.
no clue. I haven't removed the head to inspect...
90 ST185
Locker
Postby celicast184 » Mon May 30, 2016 4:52 pm
They aren't sleeved.... They are all iron blocks
I <3 MY ST214
celicast184
Postby JDMSD1 » Mon May 30, 2016 4:57 pm
That's what I thought
JDMSD1
Postby MWP » Mon May 30, 2016 5:01 pm
celicast184 wrote:They aren't sleeved.... They are all iron blocks
This ^.
The only way you could have a sleeved 3S or 5S block is if it was done by a machine shop during a rebuild later in the engines life.
Postby celicast184 » Mon May 30, 2016 5:05 pm
All aluminum blocks come sleeved factory...
I <3 MY ST214
celicast184
Return to FAQ / Archive
