The truth about ST215 3sgte engine
Re: The truth about ST215 3sgte engine
Postby Nitro_Alltrac » Thu Jun 02, 2016 9:13 pm
celicast184 wrote:All aluminum blocks come sleeved factory...
Aluminum yes, but the 3S/5S blocks are iron.
Mike
92 All Trac - Daily Driver
Nitro_Alltrac
Postby abraxxa » Mon Jun 20, 2016 7:51 pm
I've posted this here multiple times already:
I don't know why and from whom it was sleeved but my ST215 Gen 4 automatic has sleeves!
facelift ST205
abraxxa
Postby JDMSD1 » Mon Jun 20, 2016 8:41 pm
I'd say so.
That's the only mod?
JDMSD1
Postby abraxxa » Mon Jun 20, 2016 9:16 pm
When I bought it, yes.
Now it's a 2.2l BC stroker with an EFR7064 @ 1.8bar.
facelift ST205
abraxxa
Postby JDMSD1 » Mon Jun 20, 2016 9:23 pm
Which year crank did you use?
JDMSD1
Postby abraxxa » Mon Jun 20, 2016 9:26 pm
The Brian Crower one :P
facelift ST205
abraxxa
Postby JDMSD1 » Mon Jun 20, 2016 10:05 pm
Big money
JDMSD1
Postby MWP » Thu Aug 25, 2016 3:58 pm
Has anyone ever broken a crank?
Postby underscore » Thu Aug 25, 2016 4:59 pm
I'd wager that someone has, but I'd also wager a lot of other damage happened and it wasn't the part that failed initially.
Postby MWP » Thu Aug 25, 2016 5:41 pm
Yeah, agreed.
Toyota forged cranks are generally unbreakable. Surrounding parts fail first.
Postby CSAlltrac » Sun Aug 28, 2016 3:14 pm
MWP wrote:Yeah, agreed.
I'm pretty sure Ryan (BADNEWS) was the one that broke a crank, but when you're playing with the power he is, everything breaks. Pretty sure that had an effect on his board name choice.
Postby deepsky » Tue Apr 25, 2017 5:45 am
I'm starting this swap from Gen2 ST185. I need a new throttle cable. Since it appears I could get by with a shorter one, any suggestions on an alternate cable I could get?
Also someone showed a pic of a WTA on their Gen4. I'm assuming that Celica WTA was modded, I don't think it will bolt on, correct?
deepsky
Postby FC Zach » Tue Apr 25, 2017 6:12 am
I also needed a shorter throttle cable but on my Mazda. . . I shortened my cable instead of replacing it. I reused the threaded end at the TB by carefully heating it with a torch while pulling the cable housing till it was free (mount in vise or whatever). Then trimmed the cable housing to desired length (after cutting the factory cable end off and pulling cable through). I reinstalled the threaded cable housing adjustment by heating it once again but just enough to melt the desired length of cable housing in place. Pull cable through and . . .
You'll need a new cable end unless you can successfully drill through the OE one and solder it back in place but if not you can get one from almost and hardware store.
Trim excess cable end and done!
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby deepsky » Wed Apr 26, 2017 6:00 am
Great info. The problem for me is my cable sheath is all cracked.
deepsky
Return to FAQ / Archive
