parts needed to swap the turbo
Postby Denver_whiteST185 » Thu Feb 22, 2007 6:07 am
I'm wondering what new parts i would need to swap out the turbo with another stock turbo. i figured i can replace the HFH and the HFHOE, and a new manifold to turbo gasket and a turbo to downpipe gasket. what else should i replace when i do this. part numbers would be appreciated as i will probably make this a sticky for others to reference. thanks.
These are the part numbers i have now
ST185:
Hfh: 16283-88381
Hfhoe: 16282-88380
04175-74030 Turbo gasket set
17173-88381 Exhaust manifold gaskets
Last edited by Denver_whiteST185 on Thu Feb 22, 2007 7:15 am, edited 2 times in total.
^Ted^
Denver_whiteST185
Postby d1alltrac » Thu Feb 22, 2007 7:08 am
I would just get the turbo gasket set, you'll have some stuff left over but it has everything you need minus the exhaust manifold gasket.
from the part number sticky:
Patrick R.
88 ST165 x2
92 MR2 turbo
02 330i
d1alltrac
Postby Denver_whiteST185 » Thu Feb 22, 2007 7:14 am
updated first post. again, i want this to be a sticky for do-it-yourself people
What is included in the turbo gasket kit?
Also, i would like to make the first post good for both ST185's and ST165's.
^Ted^
Denver_whiteST185
Return to FAQ / Archive
