Changing your gauge backlighting color
Postby Kool_Aider » Fri Jul 20, 2007 9:17 pm
WarTowels wrote:I mostly look at pictures...
I can't read or write.
(Thanks btw.)
What was the total cost?
About 60 bucks... but I ended up not needing a lot of the bulbs so it came to the 40-50$ range. Great investment.
1992 Toyota Celica GT-S * almost 1/2 Trac
Custom White LED gauge how-to
Kool_Aider
Postby Autobot » Tue Jul 24, 2007 3:59 am
Nice write up.
Autobot
Postby syko says » Tue Jul 24, 2007 6:25 am
im probably retarded for asking this question (as i am wiring retarded) but since your car is a GTS, does your car and my car (AllTrac) use the same type of bulbs that you listed, or would i need to get different ones?
Aloha,
Evan
syko says
Postby Dracov » Tue Jul 24, 2007 8:20 am
You can use this site to verify bulb sizes used in your vehicle:
http://www.sylvania.com/ConsumerProduct ... mentGuide/
But generally speaking, for the instrument cluster, the backlights of the same generation Celica should be identical, save for possibly feature differences (ABS light, etc). Changing the instrument lights is essentially plug & play, no real wiring work needed. :)
The large bulb sockets are size 168/194, the small sockets are size 74.
1988 Toyota Celica Alltrac
Dracov
Postby Toxygene » Tue Jul 24, 2007 5:14 pm
I have a spare Radio Surround Bezel and I have had a hell of a time trying to remove the cigarette lighter surrounding piece. Any suggestions?
Toxygene
Postby WarTowels » Wed Sep 19, 2007 7:04 pm
Hey, a bit old.
I removed my cig lighter to reroute the adapter.
I don't remember exactly how I did it. It was a little weird. I had to just keep turning it in different directions and sorta jiggling it around. Careful, some of the plastic is fragile... not sure if that helps.
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby etantshi » Wed Sep 19, 2007 11:33 pm
ya it basically pops out with a little convincing.
André B.
1991 ST185 (down but not out)
1996 RZN140 (the daily)
etantshi
Postby aych » Sat Apr 26, 2008 12:23 am
yes! i finally re-found this thread. was wondering if anyone knew if you placed 2 colors of bulbs for backlighting on a 1990 alltrac dash, you would get a 2 toned dash?
aych
Postby sbart83 » Wed May 28, 2008 11:26 pm
can anyone describe the same method, but on a 165 dash cluster? what are the differences between the 4th and 5th gen bulbs? which LEDs are recomended for a st165?
88' St165 #7114
91' Ford E250 Econoline
check out Myspace.com/Machinegunvendetta !
sbart83
Postby aus jd 2703 » Thu May 29, 2008 12:33 am
how much difference is there between fully dimmed and fully bright?
i find on like drive i barely have dash lights on is this possible?
aus jd 2703
Postby klue » Thu May 29, 2008 5:03 pm
st165 uses the same types 94, 74. I had to heavily modify my cluster to get a decent light output
Postby sbart83 » Mon Jun 09, 2008 9:39 pm
what do you mean by heavily modify? i looked on the back of the 165 cluster. i calculated i will need:
4X WLED x 5 LED wedge base bulbs for back lighting
4X WLED x 5 LED wedge base bulbs (in white) for turn signal, high beam, and low fuel lights
9X #74 wedge base bulbs for dummy lights in white
the super bright led website is great, found the lights right away. they say also that there can be a flashing problem for the turn signals due to the low voltage usage, any problems for anyone?
now also they say a red lens will filter out all colors but the red color in the spectrum of light. going by this, would you use the bulbs that correspond to which warning bulb on the cluster? for example
165 CEL- amber-------> use amber bulb?
165 seatbelt light- red--------> red bulb?
catch my drift?
88' St165 #7114
sbart83
Postby klue » Mon Jun 09, 2008 10:03 pm
I had to open the cluster and modify the light distributors to get the output i wanted. I also had to remove the opaque paint on the back of the gauge face
Return to FAQ / Archive
