Oil catch can pros & cons
Postby smog7 » Sat Sep 27, 2008 6:24 am
hmm, I am surprised that nobody has mentioned that the 3rd gen 3sgte came stock from the factory with an oil catch can... I doubt toyota engineers are idiots..on a side note, i'm eventually going to go with a diy catch can like this:
http://www.celicatech.com/forums/showth ... 634&page=1
-omar
rally tarmac 1990 st185
smog7
Postby BriinumsBo » Sat Sep 27, 2008 7:21 am
smog7 wrote:hmm, I am surprised that nobody has mentioned that the 3rd gen 3sgte came stock from the factory with an oil catch can... I doubt toyota engineers are idiots..on a side note, i'm eventually going to go with a diy catch can like this:
any links of the 3g catch can? are drivers told to clean them?
BriinumsBo
Postby Kcman91gts » Sat Oct 04, 2008 9:22 pm
Hey , speaking of catch cans , i was wondering if anyone could possibly provide some insight as to whats happening in my engine ... i know my valve seals are going because im getting a shitload of carbon build up around the tip of my tailpipe with some slight liquid / condensation
but in my catch can , sometimes its a slight foamy brown , other times its a mix between black and brown and sometimes looks like pourly stirred coffee .. and even sometimes it has actual water in the bottom with the oil floating on the top.
now some of my friends are saying it could possibly be coolant leaking past the headgasket into my combo chamber .. others are saying possibly excess fuel considering it usually smells like fuel when i dump it out (heavily)
this also started to happen on my other engine when i first installed my catch can and shortly after the engine blew .. (oil pump went)
Kcman91gts
Postby BriinumsBo » Sun Oct 05, 2008 8:47 pm
gen3 catch can (type of).
no idea why there is additional catch can.
http://translate.google.com/translate?u ... l=ja&tl=en
Image Image Image Image Image Image
BriinumsBo
Return to FAQ / Archive
