1988 Supra turbo MAF in all trac?
Postby bebebullet2001 » Mon Jun 02, 2008 4:24 am
ok so i know to can play with the fuel map with a screw on the supra turbo MAF sensors and i was wondering if they will work on my all trac. i wanna up the boost and if it swaps over i wanna try it to add more fuel. what the max boost the stock injectors can hadle? i heard 9psi and the i heard 15psi, if anyone knows then pass it on to me. thanks!
bebebullet2001
Postby 88Allheeze » Fri Feb 27, 2009 11:25 pm
The supra maf is a non flapper door type and will not be direct swap, u would have to run a supra ecu somehow if u want to run the supra maf, i believe the supra is a hotwire maf type, as for the boost level on the stock setup, i wouldnt run more than 12 psi, i beleve ull get fuel cut with the PIM sensor after 12 if remember correctly. If you are upping you boost more than stock, i would have a wideband or you chance wrecking your engine
88Allheeze
Postby Greg_Canada » Wed Oct 28, 2009 3:25 pm
He means a 7mgte AFM not a 2jz MAF.
1989 4runner lifted, way too many mods
1999 4runner limited, IPF lights, JVC screen
Greg_Canada
Also, many 7mgte supra owners go to a 1uz AFM from the LS400's.... FYI.
Greg_Canada
Postby d1alltrac » Thu Oct 29, 2009 5:26 am
Greg_Canada wrote:He means a 7mgte AFM not a 2jz MAF.
the 7MGTE uses a karman vortex MAF as well. IIRC the 7MGE and 5M use flapper door AFM's, but neither of those would be an upgrade.
Patrick R.
88 ST165 x2
92 MR2 turbo
02 330i
d1alltrac
Postby Greg_Canada » Sat Oct 31, 2009 3:02 pm
Interesting.
Greg_Canada
Return to FAQ / Archive
