Sluggish Performance Problem (SOLVED)
Postby Guest » Sun Aug 08, 2004 2:39 pm
guys,
you are my last chance! Tomorrow I have an engagement at the government who looks whether my car is ok and I get my licence plates so that I can drive on roads legally. But at the moment it works nothing!I measured that I have stock fuel pressure.
The car ST185 CS, totally stock; hasn't been moved for one or two years! I just bought the car, rebuilt the engine (pistons, bearings, HG, some sealings and belts)
My problem is:
When I push the throttle, the boost goes up but the car doesn't really show power. It has full boost but no power!
The car is totally stock and I didn't modify anything!
I changed the following parts:
AFM, ECU, fuel pump, complete injector rail, TB, TMIC, MAP sensor
I don't know what I should change now and how I can find a solution! Maybe anybody of you had the same problem, or somebody has a suggestion what else I can try, but I don't know anything else at the moment!
thanks in advance
mario
Guest
Postby st185-sainz » Sun Aug 08, 2004 2:46 pm
I really thought that I was logged in...
It's me again!
Mario,
ST205 blue: completely stock
ST185CS (white): white - gravel/snow spec, dog box, TRD clutch, uprated turbo, lightened flywheel, uprated actuator, cold air intake, ST182 cams, walbro pump, batt relocation, forgies, programmable ECU (dyno), ...
st185-sainz
Postby mofoparrot » Sun Aug 08, 2004 5:10 pm
Well, I had something of the sort of the same problem, and we reduced it to being clogged cat's. Hope that helps.
1990 ST185 sold
West Hartford, CT
mofoparrot
Postby Guest » Sun Aug 08, 2004 5:54 pm
at the moment I also changed the whole exhaust system! the cats are ok!
Guest
Postby -==L=a=N=c=E==- » Sun Aug 08, 2004 7:29 pm
Full boost and no power? sounds like ya ECU is retarding all your timing. Therefore no power.
Is your knock sensor connected, and is it working?
-==L=a=N=c=E==-
Postby mototebok » Mon Aug 09, 2004 11:06 am
I vote knock sensor as well.
-Adam
'88 Alltrac .... Got a shiny new turbo
'94 RX7 .... Other money black hole
'00 ZX6R .... Lime Green Speed Machine
mototebok
Postby st185-sainz » Mon Aug 09, 2004 1:30 pm
I got it now! It was the ignition timing! It was not properly adjusted. It ignited 20 deg after ODC!!! Therefore it was not running properly!
this post can be closed.
thanks for all your help!
mario
Mario,
st185-sainz
Postby mototebok » Mon Aug 09, 2004 1:34 pm
Excellent! Glad you got it running :D
-Adam
mototebok
Postby alltracman78 » Mon Aug 09, 2004 10:26 pm
st185-sainz wrote:It ignited 20 deg after ODC!!!
mario
What's ODC? Or is it just a typo?
Return to FAQ / Archive
