Preparing an engine for long term storage
Postby GT4RC » Mon Aug 18, 2008 5:09 pm
Hi guys, need a bit of advice, and figure there should be a sticky in here about it anyways.
How should one prepare an engine for long term storage?
GT4RC
Postby Sifu » Mon Aug 18, 2008 5:52 pm
Here's what I do...
- Fill with higher octane gas
- Change oil (only if it's old)
- Put Bounty sheets in the car
- Keep one window cracked open (just barely)
- Put mouse traps under car
- Plug muffler with a sock (because I've had rice stored in there by the same critters)
- Get a good battery charger that you can keep plugged in
BROKEN! BUT NOT BEATEN!
2005 Scion tC FW21
1985 AW11
1987 AW11
Sifu
Postby GT4RC » Tue Aug 19, 2008 7:00 am
Sifu wrote:Here's what I do...
Heh, I don't think I gotta worry about the bounty sheets and the windows :P
These are the last pics I took of her.
I basically just need to know how to store it so the engine doesnt dry up.
Oh and the thread about using castors on the bottom of the cross member was an absolute lifesaver :D
GT4RC
Postby Sifu » Tue Aug 19, 2008 2:11 pm
Put in about a tablespoon of oil in each cylinder and cover with a bag so no moisture gets in it. Even putting Bounty sheets will help in the bad. Plus it'll smell like Spring freshness when you open it up... MMMMMMMmmmMmMm ahhhhhhhhh...
Also tape up all the ends of wire and hose connections so they don't get dried up, debris stuck in it, etc.
2005 Scion tC FW21
1985 AW11
1987 AW11
Sifu
Postby GT4RC » Tue Aug 19, 2008 8:59 pm
Sifu wrote:Put in about a tablespoon of oil in each cylinder and cover with a bag so no moisture gets in it. Even putting Bounty sheets will help in the bad. Plus it'll smell like Spring freshness when you open it up... MMMMMMMmmmMmMm ahhhhhhhhh...
Ok sounds idea.
I also had a guy tell me about some foam lubricant im supposed to get to fill hoses, cylinders, etc... but I forgot what it's called.
anyone know of the stuff? :shrug:
GT4RC
Postby Sifu » Tue Aug 19, 2008 10:14 pm
Hmm... Never heard of it but taping it should be ok. It's not going to be stored for years...
2005 Scion tC FW21
1985 AW11
1987 AW11
Sifu
Return to FAQ / Archive
