How much amps pulls when car is off?
Postby purplecelicaGt4 » Mon Nov 03, 2008 12:36 am
ok my car has electrical problems... I find that the window motor does not disengage after it powers up or down the window.. If its on it pulls 7 amps.. Even tho the car is off and the kee is out it still pulls the 7 amps//
With everything off including the window motor.. The car pulls.005 amps..
Is that a problem?? Will that pull the battery down over night??
How much amps your car pulls when its off?
1990 celica gt4
Postby bridge47 » Mon Nov 17, 2008 10:38 pm
I believe less than 1/2 an amp is normal.
Facts are stubborn things.
Postby TomsGT4 » Wed Dec 17, 2008 1:17 am
5 MilliAmps is a very small draw.
It would take weeks for the battery to drain when off.
Anything over 100 mA could be something that should be switching off, but isn't.
1990 ST185
1990 Corolla SR5
Return to FAQ / Archive
