JDM 165 ECU Pinout
JDM 165 ECU Pinout
Postby GT4165 » Wed Nov 12, 2008 2:19 am
Hi, I was recently installing a FCD Bypass thing and on both the instructions is came with and the ecu pinout sheet i printed out the wires they said to cut were a different colour... anyone have a JDM ECU Pinout for a 165 they could help me with?
GT4165
Postby GT4165 » Wed Nov 19, 2008 1:34 am
:cry: not even enough revs for fulll boost... anyone got any idea?
GT4165
Postby codester » Thu Nov 20, 2008 2:06 am
A little less than halfway down the page. Not exactaly a perfect "pin out" but might help.
http://www.gtfour.ca/howtoswap.html
codester
Postby jingo11 » Mon Dec 08, 2008 4:07 pm
here ya go mate
open with Excel
jingo11
Postby jingo11 » Mon Dec 08, 2008 4:10 pm
what stock boost gauge do you have?
ie a proper in built gauge or just a light?
the wire to tasp into should be red and white if you have a factory fitted gauge
if you do not have the red and white PIM wire let me know and i will dig out the other instructions
Hope it helps mate
Jingo
jingo11
Postby GT4165 » Mon Dec 08, 2008 9:05 pm
Thanks all for the replies, Jingo11 it has a green whire where the pim wire is supposed to be no red and white i could see,im going to give it another go with the pinout u provided and hopefully it will be the same wiring
GT4165
Postby GT4165 » Mon Dec 08, 2008 9:25 pm
GT4165 wrote:Thanks all for the replies,Where is the PIM whire on the Pinout u posted? under another name? Jingo11 it has a green whire where the pim wire is supposed to be no red and white i could see,im going to give it another go with the pinout u provided and hopefully it will be the same wiring
GT4165
Return to FAQ / Archive
