URGENT HELP ST165
URGENT HELP ST165
Postby GT4165 » Sat Jan 31, 2009 11:02 am
First off ill tell you the situation, i bought a 165 gt-four recently and found out that its tunning a stock 162 radiator which is keeping the radiator fan on constantly. So i purchased a PWR alloy radiator but am stuck with the problem that i have no idea what fan switch goes into the bottom of the radiator, is it the same as a 185 or is it compleetly different, due to the lack of st165's in australia no one has a clue so if i had a part number or pictute and dimentions so i can get an aftermarket one i can finally drive my baby again.
Thanks heaps guys
GT4165
Postby Rick89GTS » Mon Feb 09, 2009 6:41 am
There is a coolant temperature sensor that goes in the bottom of the radiator. I'll find the dimensions for you and post it. I don't know if the 185 sensor is the same or not.
Rick89GTS
Postby Rick89GTS » Mon Feb 09, 2009 6:55 am
The size of the coolant temperature sensor that fits is M16 x 1.5.
Rick89GTS
Postby GT4165 » Mon Feb 09, 2009 9:35 pm
Great, u wouldnt have a part number for it would you?
GT4165
Postby Rick89GTS » Mon Feb 09, 2009 11:33 pm
No, but there are many online sources you can find it. You can also email a request to www.1sttoyotaparts.com
Rick89GTS
Return to FAQ / Archive
