[Toyota Part Numbers]
Postby turbo4wd » Mon Mar 21, 2005 7:36 pm
b00staholic wrote:Anyone got OEM ignition component part #s? Preferably for a 90-91...
Spark plug wires, cap and rotor, etc.?
1910274040-Distributor Rotor
1910188363-Distributor Cap
Thats for a 91.. probably the same for 90..
not sure about wires.. but plugs are denso brand.. forgot what the part # was but you should be able to look it up..
Dan
Undercover Moderator
turbo4wd
Postby 3sge » Tue Mar 22, 2005 7:15 pm
Anyone know the part number for the 55mm air intake connector(rubber part that bolts to the TB) got the number for the stock 50mm one
air intake connector 17861-88382 (50mm)
3sge
Postby Austen_gt4 » Sat Apr 02, 2005 6:21 pm
18X w/o abs
proportioning valve w/o abs 47150-20160 167.41
front brake no4 w/o abs 47314-20360 16.03
front brake no1 w/o abs 47311-20710 10.79
front brake no3 w/o abs 47313-20480 10.50
2006-DURAMAX RaPeVaN
2008-RUCKUS
2004-IS300
1993-MR2T X 2
1992-GT4
1991-SPEC MIATA
LOTUS 7 (in progress)
Austen_gt4
Postby turbo4wd » Tue Jun 28, 2005 2:20 pm
Here are more part numbers to add to the mix.. These are part numbers that apply to my car (91 st185).. So I'm not sure if they apply to 92-93 185s.. Any Toyota dlr can run your vin to verify..
87245-2B540 HEATER HOSE
87245-2B560 HEATER HOSE
16100-79126 WATER PUMP
15100-88381 OIL PUMP
04111-74170 ENGINE GASKET OVERHAUL KIT
13568-79045 TIMING BELT
90919-21473 SPARK PLUG WIRES
Dan
turbo4wd
Postby moee24 » Mon Jul 11, 2005 11:17 pm
st165 fuel injector o-rings to cylinder head : 23291-41010
moee24
Postby turbo4wd » Thu Jul 28, 2005 1:00 am
90341-18033 PLUG (FOR MANUAL TRANSMISSION FILLER)
90430-18008 GASKET (FOR MANUAL TRANSMISSION FILLER PLUG)
90430-18008 GASKET, DRAIN PLUG (MTM)
90341-18006 PLUG SUB-ASSY, DRAIN (MTM)
Dan
turbo4wd
Postby gpmarzan » Thu Jul 28, 2005 11:23 am
17882-74070 Intake Hose for the st165 (same as st185??) Its the hose that connects to the turbo.
16400-74171 st165 Radiator
Patrick M.
st165
gpmarzan
Postby Rick89GTS » Thu Aug 04, 2005 11:38 pm
gpmarzan wrote:17882-74070 Intake Hose for the st165 (same as st185??) Its the hose that connects to the turbo....
Nope, 185 is a different part number; different size.
04422-20010: Oil Seal kit for front wheel bearings; ST165 & ST185 (88-93)
90916-03090: Thermostat ST165
Rick89GTS
Postby d1alltrac » Wed Aug 10, 2005 3:25 am
i need the part # for the rubber elbow that connects the metal part of the turbo oil return line to the oilpan on 165's...here's a diagram:
hopefully someone can help
Patrick R.
88 ST165 x2
92 MR2 turbo
02 330i
d1alltrac
Postby pepper » Wed Aug 10, 2005 5:16 am
d1alltrac wrote:i need the part # for the rubber elbow that connects the metal part of the turbo oil return line to the oilpan on 165's
Looks like it's "Hose, Turbo Oil Outlet", #15491-88380
-Mike
Mike
'88 ST165
Vancouver, WA USA ------------------------------ mine
pepper
Postby turbo4wd » Wed Aug 10, 2005 11:30 pm
Cut and pasted from the other thread about ECU Part Numbers..
UK 185 ecu's-
89661-20770=89/10-91/08
89661-2b320=91/08-92/02
89661-2b300=92/02-93/11
JDM 185 ecu's-
89661-20750=89/10-90/03(superceeded to 20751)
89661-20751=90/03-91/08
89661-2b310=91/08-92/02
89661-2b280=91/08-93/09
UK 205 ecu-
89661-2b850
JDM 205 ecu
89661-2b841=94/02-95/03
Dan
turbo4wd
Postby jprine01 » Thu Sep 08, 2005 7:06 pm
Austen_gt4 wrote:18X w/o abs
Man, so i bought all the non abs stuff, orderd 5 lines, proportioning valve, the 3way etc. (the line not listed above is 47315-20491 front break no.5) goes to the left wheel... Anyway I got everything in the mail but one thing "front brake no3 w/o abs 47313-20480" says Discontiuned on my invoice. !!!! noooooooo, so now i have to find one at the junkyard or get one made who knows... Common toyota keep our parts around!! :( sad day for me.
jprine01
Postby Stubble » Sat Oct 29, 2005 12:51 am
Transmission related (sorry but I don't know which is which)
33369-20010 Synchro ring
33367-20040 Synchro ring
33367-20060 Synchro ring
33368-20040 Synchro ring
90365-30023 Bearing
90363-33007 Bearing
90366-28007 Bearing
90366-32002 Bearing
90364-36007 Bearing
90364-36010 Bearing
90364-39008 Bearing
90364-33004 Bearing
This will get you a complete tranny rebuild, replacing all the synchros and bearings in a E150F tranny (1990 ST185 US/CanDM)
Brady Ryall
1990 ST185 Red - parts
1990 ST185 Black
1999 Miata
2008 A3 Quattro S-line
Stubble
Postby Stubble » Sat Oct 29, 2005 1:01 am
More p/n's:
45046-19175 Tie rod end
83710-20880 Speedometer cable, tranny to firewall
13540-88381 Timing belt tensioner
13505-88382 Timing belt idler pulley (not sure which one, there are 2)
90930-03148 Freeze plug set
11701-88342-0_ Main bearing (specify the size with the last digit)
11071-88570-0_ #3 Main bearing (specify the size with the last digit)
11011-25010 Main thrust washer (bearing)
04175-74030 Turbo gasket set (90-91; comes with o/h gasket set for 92-93)
99363-70760-83 Power steering belt
11122-88320 Valve guide bushings
23300-19225 Fuel filter
Brady Ryall
1990 ST185 Black
1999 Miata
Stubble
Postby Stubble » Wed Nov 02, 2005 1:36 am
More for a '90 ST185
43330-29326 Ball joints
90179-12065 Trailing arm nuts (can't determine front or rear) 90179-12065
19127-74040 Distributor cap o-ring
90099-14090 Distributor shaft o-ring
90311-52005 Rear wheel bearing outer oil seal
42210-14010 Spherical bearings for rear control arm outer pivots (camry part listed in EPC)
Brady Ryall
1990 ST185 Black
1999 Miata
Stubble
Return to FAQ / Archive
