[Toyota Part Numbers]
Postby Conan » Wed Mar 19, 2008 4:35 am
TheNubkins wrote:Are there any parts on this diagram that do not comprise the air/water intercooler setup
Yes, there's the transmission cooler, AC tank, main fan and head lamp sprayer hoses.
TheNubkins wrote:and would I be correct to assume that if I were to purchase all the parts on this diagram I would be able to install them in my stock North American All Trac Turbo to replace my air/air intercooler setup?
I'm not sure, you would need a new IC to TB hose and maybe drill a few holes here and there :) Also, you need to wire the pump somewhere.
TheNubkins wrote:Anyone know the part number for the turbo-to-manifold gasket?
It should be somewhere around here, search and you will find :wink:
Conan
Postby TheNubkins » Wed Mar 19, 2008 10:50 pm
Thanks Conan. You sure know your stuff. :)
The Nubkins
-2001 VW Golf TDI
TheNubkins
Postby Flying Bajan » Thu Apr 03, 2008 5:15 pm
Conan wrote:
Flying Bajan wrote:So I've heard... Any idea on price ?
Around a grand. US part is half the price I doubt it fits though.
Flying Bajan wrote:Also, my car is a 1990 narrow body JDM car, not questioning you, but are you sure that is the right number ?
83242-15610 for the narrow body shared with some ST182s.
Conan, been searching and all the sources I've tried are saying this number is wrong... Any possibility of them being right ?
Can you source one ? Again, the car in question is a 1990 model (built in November of 1989), narrow body, right hand drive, Japanese domestic market, ST185 GT Four.
Cheers,
Martin.
Flying Bajan
Postby Conan » Thu Apr 03, 2008 7:02 pm
Flying Bajan wrote:Conan, been searching and all the sources I've tried are saying this number is wrong... Any possibility of them being right ?
I have checked again, it's the same number.
Flying Bajan wrote:Can you source one ?
I guess I could but it would cost a LOT from the dealer.
Conan
Postby Flying Bajan » Fri Apr 04, 2008 2:30 pm
Thanks again Conan, I realise this part is going to be fairly expensive, and while I don't have a ton of money to throw around, this particular car is in such good shape that it really deserves to heve everything working correctly on it and not be bastardised too much.
I'd be grateful if you could get a quote on one for me. Feel free to email it directly to me at flyingbajan@hotmail.com
Best regards,
Martin.
Flying Bajan
Postby Corey » Sun Apr 06, 2008 4:23 pm
Would it be possible to find the part number for an OEM toyota key?
I asked local toyota, and they have never seen an OEM key like it.
It says Celica on it, has the Keyless entry button on the side.
Ill grab a picture later,
Thanks
Corey
Corey
Images: 50
Postby Nitro_Alltrac » Sun Apr 06, 2008 8:01 pm
I found these numbers on the very first page but I'm not sure which one is the one I need. I am needing the number for the two washer/gaskets that go on the turbo oil feed line where it attaches to the block. There is one on the top and one of the bottom of the banjo fitting. The numbers I found are:
gasket, joint for turbo oil pipe - 15526-88381
Turbo oil line gasket - 15471-88580
Which one is correct for what I need?
Thanks.
Mike
92 All Trac - Daily Driver
Nitro_Alltrac
Postby smog7 » Mon Apr 07, 2008 2:41 am
anyone have the numbers for the little clips that hold the rubber air duct to the stock a2a intercooler?
-omar
rally tarmac 1990 st185
smog7
Postby BLOWNTACO » Mon Apr 07, 2008 11:11 am
There isn't any from I could find. The only way to get the clips is buy another one. Nice huh?
A wise and frugal government, which shall leave men free to regulate their own pursuits of industry and improvement, and shall not take from the mouth of labor the bread it has earned - this is the sum of good government.
-Thomas Jefferson
BLOWNTACO
Postby Nitro_Alltrac » Mon Apr 07, 2008 8:36 pm
Nitro_Alltrac wrote:I found these numbers on the very first page but I'm not sure which one is the one I need. I am needing the number for the two washer/gaskets that go on the turbo oil feed line where it attaches to the block. There is one on the top and one of the bottom of the banjo fitting. The numbers I found are:
Thanks.
Can anyone answer the question on these? I really need to get a couple.
Thanks.
Mike
Nitro_Alltrac
Postby smog7 » Mon Apr 07, 2008 8:44 pm
BLOWNTACO wrote:There isn't any from I could find. The only way to get the clips is buy another one. Nice huh?
damn! well that sucks
-omar
smog7
Postby Gary ST165 » Mon Apr 07, 2008 9:28 pm
Thanks.
Thanks.
GASKET, JOINT (FOR TURBO OIL PIPE) ST185 part# 15526-88381
ST165 turbo 4WD
Gary ST165
Postby Nitro_Alltrac » Mon Apr 07, 2008 10:01 pm
Thanks Gary! That is exactly what I needed.
Do you have any suggestions on where to get a copy of the EPC that will work? I downloaded one that was linked to a post here. It installed but I never could get it to work. It wouldn't recognise the catalog files.
Mike
Nitro_Alltrac
Postby Nitro_Alltrac » Tue Apr 08, 2008 12:43 am
Thanks Gary. I'll give this a try.
Mike
Nitro_Alltrac
Postby Conan » Tue Apr 08, 2008 6:21 am
Gary, you filthy pirate! :D
Conan
Return to FAQ / Archive
