[Toyota Part Numbers]
Postby robolt » Fri Jun 27, 2008 10:55 am
Took a close look and could not find any part numbers on the calipers.
The only things I can find other than the SUMITOMO are some stampings
On the Rears, I can find a 3 Y 2J (same on both calipers)
On the Fronts, I find a A 1 B J on one and M 5 4 on the other.
Difficult to read, but not of much use.
'90 CS conversion
240Z, Super 7, + others...
You are in a maze of twisty little passages, all alike
robolt
Images: 2
Location: California, Long Beach, SF Bay Area, Foothills USA
Postby sbart83 » Sat Nov 15, 2008 2:30 am
need part numbers for usdm 88 st165:
speedo cable
timing belt
spark plugs and this hose, comes outunder the water bypass junction and connects somewhere by the hard lines...
88' St165 #7114
91' Ford E250 Econoline
check out Myspace.com/Machinegunvendetta !
sbart83
Postby Corey » Sun Dec 07, 2008 11:49 pm
This is an amazing part number resource.
Even has RHD part numbers for the rally, V, A, and RC !
http://www.toyodiy.com/
Corey
Images: 50
Postby alltracshoak » Fri Dec 19, 2008 12:51 am
Denver_whiteST185 wrote:the toyota parts guy gave me:
90311-38032 for the rear output seal
just wondering if this is for the rear seal on the center diff where the driveshaft goes in ?
current:
90 st185
GT4 AWD
rip: 92 st185 @ 178k :(
alltracshoak
Postby BLOWNTACO » Fri Dec 19, 2008 11:17 am
Yup!!! That's the one out of the tailshaft housing off the back of the x-fer.
A wise and frugal government, which shall leave men free to regulate their own pursuits of industry and improvement, and shall not take from the mouth of labor the bread it has earned - this is the sum of good government.
-Thomas Jefferson
BLOWNTACO
Right rear fender liner ?
Postby Flying Bajan » Sat Jan 17, 2009 1:47 pm
Hi folks,
Anyone have the part number for the small piece of plastic that fits in the right rear fender in a manner similar to a fender liner ? My car appears to be missing it as there is such a thing installed in the left rear, but not the right rear.
The car is a narrow bodied JDM ST 185, chassis number ST185-0000249.
Cheers !
Martin.
Flying Bajan
Postby Corey » Sat Jan 17, 2009 11:03 pm
^^ mine is like that also.... :shrug:
Corey
Images: 50
Postby Flying Bajan » Mon Jan 19, 2009 2:27 pm
Maybe it's meant to be like that then ? Seems strange as there appear to be mounting holes present for a fender liner. :shrug:
Flying Bajan
Postby banshee 101 » Sat Jun 13, 2009 12:09 am
would need to part number for rear brakes rotors, shoes for handbrake
ole hub, or just the bearing.
thanks
banshee 101
Postby MrMcQuacker » Mon Aug 17, 2009 1:41 am
hey guys im looking for either the exact same type of screws or the oem part number for these screws. i need the part numbers for the motor and tranny bolts to the cross member on the st165 please ty.
MrMcQuacker
Postby Gary ST165 » Mon Aug 17, 2009 9:56 am
MrMcQuacker wrote:hey guys im looking for either the exact same type of screws or the oem part number for these screws. i need the part numbers for the motor and tranny bolts to the cross member on the st165 please ty.
should be on here: http://www.toyodiy.com/parts/p_U_1988_T ... _1107.html
ST165 turbo 4WD
Gary ST165
Postby Flying Bajan » Sat Oct 31, 2009 8:52 pm
Trying to find the part numbers (and a source new or in good condition used) for the fittings / plastic screws that hold on the inner trunk / boot liner / plastic trim piece that covers the entire rearmost section of that area. In grey please :-)
Flying Bajan
Postby Gary ST165 » Sun Nov 01, 2009 1:23 am
Flying Bajan wrote:Trying to find the part numbers (and a source new or in good condition used) for the fittings / plastic screws that hold on the inner trunk / boot liner / plastic trim piece that covers the entire rearmost section of that area. In grey please :-)
http://www.toyodiy.com/parts/p_U_1991_T ... _6404.html
ST165 turbo 4WD
Gary ST165
Postby Flying Bajan » Sun Nov 01, 2009 2:50 am
Much thanks :-)
Flying Bajan
Postby Celicatuner92 » Thu Dec 10, 2009 12:29 am
alright I've serched around for these part #s for a 185 and couldn't seem to find the ones i needed for these insulators
also can someone confirm this # for the insulator on the end of the fuel rail where it goes into the head 23845-88380
90 St185_DD actual car seen on tirerack.com
90 St185_ race car
92 Celica Gt_Runnig
Celicatuner92
Return to FAQ / Archive
