[Toyota Part Numbers]
Re: [Toyota Part Numbers]
Postby Gary ST165 » Tue Nov 30, 2010 5:58 am
monkninja wrote:Alright I just got done using the Russian Illustrated parts catalog, and came up with numbers, but when I tried searching at 1sttoyotaparts it couldn't find them... stinking Russians... well this is what I came up with.
Gasket - turbine outlet elbow: 17279 (not found)
Gasket - intake manifold to head no 1: 17177 (not found)
Gasket - intake manifold no 2: 17179A (not found)
Gasket - turbo to exhaust manifold: 17278 (not found)
I have an ST185, I'm sure that makes a difference.
If anyone has part numbers that are current I would really appreciate it!!!
Thank you!!
In the above example: 17279 is the PNC #
The full part number has a minimum of 10 digits ;) xxxxx-xxxxx
17279-88381 $25.73
17177-88381 $9.16
17179-88381 No Items Found
17278-88381 $27.24
hth
ST165 turbo 4WD
Gary ST165
Postby monkninja » Tue Nov 30, 2010 4:15 pm
God bless you Gary!
Kyle
1990 AllTrac
1999 Kawasaki ZX9R (Usual daily driver)
2003 Matrix Xrs (Wife's car)
monkninja
Postby monkninja » Thu Dec 02, 2010 4:52 pm
I am trying to find the part number for the air connector between the TMIC and the turbo. I found two numbers but they vary in price dramatically, so I know they must be different and not interchangable.
Hose, air cleaner no. 1: 17659-88381 $14.76
Hose, air cleaner no. 1: 17881-74300 $53.23
Has anyone ordered them or know for sure which one is correct?
Thanks!
Kyle
edit:
Hose, air cleaner no. 1: 17659-88381 $14.76 is the correct one
Kyle
1990 AllTrac
monkninja
Postby Gary ST165 » Fri Dec 03, 2010 10:32 pm
ST165 turbo 4WD
Gary ST165
Postby monkninja » Sat Dec 04, 2010 6:25 am
Gary, that EPC is reaking perfect! I don't even know what to say... but I will say: THANK YOU!!
Kyle
1990 AllTrac
monkninja
Postby celicat93 » Wed Oct 05, 2011 8:19 pm
I looked through the whole thread and didn't see this, how about the turbo rebuild kit? That comes from Toyota, correct?
celicat93
Postby Gary ST165 » Sat Oct 08, 2011 5:17 pm
celicat93 wrote: how about the turbo rebuild kit? That comes from Toyota, correct?
nope: http://www.megazip.ru/ru/auto/toyota/vi ... st#g367047
no rebuild "kit" from toyota > you only have the option to buy a brand new turbocharger
or
find a specialist (local) turbocharger re conditioner: eg: http://www.melett.com/
ST165 turbo 4WD
Gary ST165
Postby Cuttyman9 » Fri Dec 28, 2012 1:15 am
Does anyone have the part number for the system ten door logo? The ones that are on each side that cover a mounting tab and are between the cubby and speaker?
1992 Celica GT Hatch
1971 Cutlass
1967 Chevelle
1975 Trans Am
1966 C20 Long Bed
1999 F150
Cuttyman9
Postby fussellbug » Fri Dec 28, 2012 10:03 am
System 10 logos are on page 8 of this thread:
67638-20040 PLATE, FRONT DOOR TRIM, NO.2 RH
67639-20040 PLATE, FRONT DOOR TRIM, NO.2 LH
fussellbug
Images: 36
Postby Rallly » Tue Aug 30, 2016 4:35 pm
What is the part number for st185 CYLINDER ASSY, CLUTCH RELEASE
Rallly
Postby zaluss » Tue Aug 30, 2016 5:34 pm
Rallly wrote:What is the part number for st185 CYLINDER ASSY, CLUTCH RELEASE
31470-20210
zaluss
Return to FAQ / Archive
