[Toyota Part Numbers]
Postby turbo4wd » Fri Nov 04, 2005 2:02 am
(Courtesy of Griffin)
These part numbers are for a 1990. They are ALL the coolant hoses (except the heater hoses) and a couple of the specialty vacuum hoses and the o-rings for the oil cooler. Enjoy!
Vacuum lines:
12261-88381
12263-74040
17342-88360 X2
Oil Cooler O-rings:
96732-19019
90301-52002
15785-35010
15517-88380
Coolant hoses:
16261-88361
16264-88383
16267-88382
16282-88380
16283-88381
16284-88381
95333-06040
85338-74130
90445-12078
16571-74130
16572-88381
16572-74110
Dan
Undercover Moderator
turbo4wd
Postby AlltracAvenger » Fri Nov 18, 2005 3:06 am
Three more.
Oil filter bracket O-rings(ST165):
96732-19019
96732-31055
Crush washers for oil cooler(ST165):
15785-88380(you will need six of these)
Oil cooler O-rings(ST165):
90301-22004(you will need two of these)
Hex bolts to hold CV axle to tranny(ST165/ST185?)
90110-10015(you will need six bolts per axle; it is an 8mm hex socket if I remember correctly).
'88 ST165 #2914- Sold 12/21/06 :(
'88 ST165 #3784- Bought 05/08/15 :D
'05 Corolla XRS- Daily Driver
AlltracAvenger
Postby turbo4wd » Wed Dec 14, 2005 2:01 pm
d1alltrac wrote:anyone know the part number for the 185 exhaust manifold? 7 or 9 bolt i dont really care, i just wanna try to get a new one before searching for a used one because i have heard they are relatively inexpensive
TIA
Exhaust system - Exhaust manifold
EXHAUST MANIFOLD, Celica, w/Turbo 1990 - 1993
17141-88381
MSRP: $242.59
(i would search for a used one or see if anyone has any spares lying around because depending on your discount with the dealer its still $150+.. )
Dan
turbo4wd
Postby SuperWhite92 » Sat Jan 28, 2006 8:33 am
ST185 Radio Pieces:
LH Mounting bracket: 86211-20300
RH Mounting bracket: 86212-20290
Non-System 10 Tray insert (For use with aftermarket decks: 55521-16030
Shaun
SuperWhite92
Postby RIalltrac » Tue Feb 07, 2006 2:51 pm
I saw some of these posted above, but some of the numbers are different. These part numbers and prices came from Bob Bridge toyota (1st something or other.com) for a 90 st185
oil cooler seal 15785-35010 $.72
oil cooler seal 90301-52006 $2.69
oil cooler line gasket 15471-88580 $3.95
oil pump shaft seal 15165-70010 $5.78
oil pump seal 15188-63010 $9.38
Chris - 90 ST185
RIalltrac
Images: 2
Postby Conan » Mon Mar 06, 2006 6:11 am
four twenty wrote:I was wondering if anyone had the part # for the 1990 ST185 dipstick.
Hehe, that's an easy one - 15301-88381.
Conan
Postby four twenty » Wed Mar 08, 2006 7:50 pm
Thanks a bunch.
Here's another easy one:
Are the OEM gas caps the same for all Toyotas?
If not then I need the part # for the ST165 gas cap.
Take care.
Brent
1989 ST165
Hermosa Beach, CA
four twenty
Postby TraviST185 » Fri Mar 17, 2006 3:28 pm
AC Removal-
Ribbed pulley- 16603-88360
Spacer (for bolt that went through AC compressor)- 90560-08060
40" ribbed belt
Travis Hanson
TraviST185
Postby Conan » Sun Apr 16, 2006 2:35 pm
jimjovan wrote:Can anyone tell me the part number for the ST165 dipstick or dipstick seal?
15301-88380 GAGE SUB-ASSY, OIL LEVEL
Sorry, I don't know what a dipstick seal is :shrug:
Conan
Postby Conan » Sun Apr 16, 2006 2:37 pm
NemesisGT-2 wrote:I got 31470-12093 from the dealer and it is the WRONG part.
Hehe, it's a slave cylinder just not from an ST185 ;)
This should be the one:
31470-20210 CYLINDER ASSY, CLUTCH RELEASE
Conan
Postby Conan » Sun Apr 16, 2006 2:44 pm
Toxygene wrote:Anyone have the part#'s for the ST185 Water to Air intercooler, the pump for the WTA intercooler, and the stock WTA radiator, and any wiring and hoses associated with that system?
You sure you wanna know all of this? :twisted:
Conan
Postby Conan » Tue May 16, 2006 5:11 am
Khyron wrote:Looking for the part number for a 185 fuel pump
23221-50020, the number was changed from 23221-74010.
Conan
Postby Khyron » Fri Jun 30, 2006 6:46 pm
Is there an individual part # for the external housing for the fuel pump on a 90 ST185? I have the fuel pump's # but didn't know if the housing might have a separate #. If there is and if someone knows what that might be I'd really appreciate someone posting it. My housing is shot and w/o it there's no trac for me :(
90 All-trac
92 Camry LE
07 Mazda 6
Khyron
Postby d1alltrac » Sat Aug 26, 2006 5:37 pm
incase someone else needs them
ST165 Front Caliper Rebuild Kit---04479-20110
ST165 Rear Caliper Rebuild Kit---04479-33041
not sure if these were already posted or not but here are a couple more i got.
ST165 Clutch Master Cylinder---31410-20293
ST165 Clutch Slave Cylinder---31470-32032
Patrick R.
88 ST165 x2
92 MR2 turbo
02 330i
d1alltrac
Postby toayoztan » Thu Sep 21, 2006 9:11 pm
For anyone that's curious, i got these part numbers:
185 Head bolts - 90910-02094
HVAC (climate control cluster) lights w/ black socket - 81850-20180
HVAC lights with brown socket - 81850-20290
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Return to FAQ / Archive
