[Toyota Part Numbers]
Postby BLOWNTACO » Mon Jan 01, 2007 11:49 pm
The ones on mine were to small. Slipped right through the holes in the RC motor. :shrug:
A wise and frugal government, which shall leave men free to regulate their own pursuits of industry and improvement, and shall not take from the mouth of labor the bread it has earned - this is the sum of good government.
-Thomas Jefferson
BLOWNTACO
Postby alltracman78 » Mon Jan 01, 2007 11:56 pm
The screws that hold the motor to the shroud?
Postby BLOWNTACO » Tue Jan 02, 2007 11:29 am
Yep, those are the ones.
-Thomas Jefferson
BLOWNTACO
Postby scandinavian link » Thu Jan 04, 2007 9:22 pm
kind of a weird request for an alltrac board, but does anyone know/can find the part number for the little plastic caps that go on the shifter rod(where the shifter cables connect) for a 6th gen celica?
i've got a shifter from one to stick in my bro's st185 but it came without caps, and the 185 ones don't fit.
thanks :oops:
bryan -central ohio
2000 zzt231
1988 st165 (sold)
1990 st185 (brother's)
scandinavian link
Postby Conan » Tue Jan 09, 2007 5:41 am
Only yesterday I came to understand that the CS edition uses a different valve cover (obvious) and a different gasket (weird), so here they are:
11213-88382 GASKET, CYLINDER HEAD COVER
11201-88384 COVER SUB-ASSY, CYLINDER HEAD for cars made between August 1991 and October 1991
11201-88387 COVER SUB-ASSY, CYLINDER HEAD for cars made between October 1991 and February 1992 (end of CS production)
Conan
Postby sims » Tue Jan 09, 2007 11:27 pm
does anyone know where I would be able to look up parts for a 91 JDM celica GT-Four A?
I was in a fenderbender and need to replace a few parts, its all covered by insurance but I need to provide them the parts numbers for anything thats different from the north american spec.
sims
Postby saki10man » Mon Jan 15, 2007 5:12 pm
anyone knows the part number for the alternator belt for the 165 be it OEM or aftermarket........mine is cracked to hell...... :cry:
1986 FWD 3SGTE(RIP)
2004 Kawi ZX-10
1994 Toyota Pick-up(finished rebuilding :-)
1988 Project ST165(ABANDONED)
saki10man
Postby Conan » Mon Jan 15, 2007 5:30 pm
90TURBO4WD wrote:anybody know part # for rear motor mount??
12321-74060 BRACKET, ENGINE MOUNTING, REAR (FOR TRANSVERSE ENGINE)
12371-74210 INSULATOR, ENGINE MOUNTING, REAR (FOR TRANSVERSE ENGINE)
Conan
Postby etantshi » Sat Jan 27, 2007 5:27 am
Conan wrote:Only yesterday I came to understand that the CS edition uses a different valve cover (obvious) and a different gasket (weird), so here they are:
What's so different about the CS vavle cover?
André B.
1991 ST185 (down but not out)
1996 RZN140 (the daily)
etantshi
Postby 88st165 » Fri Feb 09, 2007 9:06 pm
anyone know the part number to the rubber hanger for the midpipe on the st165?
Black st165 - gone
2011 FA5 - Family Truckster
88st165
Images: 2
Postby Conan » Mon Feb 12, 2007 10:45 am
Denver_whiteST185 wrote:Can anyone tell me the part number for the two sets of front crossmember bushings like the ones that the speedsource kit replaces?
52225-20050 CUSHION, CENTER MEMBER MOUNTING, FRONT UPPER
52240-20050 CUSHION ASSY, CENTER MEMBER MOUNTING, FRONT LOWER
52230-20060 CUSHION ASSY, CENTER MEMBER MOUNTING, REAR UPPER
52236-20050 CUSHION, CENTER MEMBER MOUNTING, REAR LOWER
Conan
Re: A bunch of numbers(JDM only)
Postby maxaud » Mon Feb 12, 2007 5:11 pm
BLOWNTACO wrote:....
Rain Visors:
08613-20130
wouldn't happen to know the part numbers for the little metal clips that hold the visors on. I'm missing one.
-Dustin
maxaud
Postby gt4tified » Fri Feb 16, 2007 12:46 pm
Part numbers for gearbox axle and driveshaft seals for the 185 puhleeease?
gt4tified
Images: 5
Postby BLOWNTACO » Fri Feb 16, 2007 8:02 pm
Hey, the metal clips may not be available. The new kit I got had them in their own little bag, no part number on any of the instructions either. I'll hunt around and see if anything pops up.
-Thomas Jefferson
BLOWNTACO
Postby maxaud » Fri Feb 16, 2007 8:50 pm
BLOWNTACO wrote:Hey, the metal clips may not be available. The new kit I got had them in their own little bag, no part number on any of the instructions either. I'll hunt around and see if anything pops up.
alright, see what you can do. I appreciate it. thanks.
Dustin
-Dustin
maxaud
Return to FAQ / Archive
