New TRD head gasket info
Postby built2run » Tue Mar 31, 2009 7:44 pm
i called a toyota dealer that can get JDM parts and talked to the japanese parts guy there cuz i was looking for a gen3 head gasket, he told me he can get a whole set and not just the gasket then he looked into the TRD.
here it is, TRD once made 2 gaskets the gen3 and gen2/1, they are different, the gen2/1 being MLS and .8mm thick(or 1.0mm) similar to gen3
the gen3 being very close to the oem gen3- the part numbers are different and the gen3 TRD gasket is discontinued
i'll post whatever part number i can get later today. the gen3 engine will run on the gen2/1 head gasket but might overheat with hard driving
chris at KO racing also told me the he just learned about the differences and here is a link to some pictures comparing the gen3 vs gen2/1
http://www.gtfours.co.uk/pics/headgaske ... askets.htm
ST165, black: parted and gone
ST165, white: sold to friend
built2run
Postby Gary ST165 » Tue Mar 31, 2009 11:06 pm
additional info:
These are the part numbers for the TRD 1.2mm and 1.4mm multilayer steel head gasket. same part# for both ST165 & ST185 correct fitment.
TD340-26177 = 1.2mm.
Part-No.AM26177 Price 59,06 EUR
TD340-26176 = 1.4mm.
Part-No.AM26176 Price 59,06 EUR
I ordered the above via TTE Germany, who informed me that the "TTE" gasket is a TRD factory item from Japan, and that TTE Germany only acted as the European service / sales agents for TRD Japan.
i would hope it is still possible to order these in .
ST165 turbo 4WD
Gary ST165
Postby built2run » Wed Apr 01, 2009 5:56 am
can someone update the tuning section about this?
built2run
Return to FAQ / Archive
