ST205 Water-to-Air Intercooler functional from factory?
Postby kkelly3201 » Tue Sep 08, 2009 6:02 pm
After some poking around online I am under the impression that the water to air function is not operational without manually setting it up, I've read that the hardware is all present, that it is just not functional. Am I missing something? I hope I'm wrong.
kkelly3201
Postby Shaggz00 » Tue Sep 08, 2009 7:45 pm
yes, you are very very wrong. link?
-Avi-
Shaggz00
Postby Corey » Tue Sep 08, 2009 7:46 pm
Huh?
Could you be more specific? Or are you talking about the factory antilag which came on the 205WRC, but was not operational?
Corey
Images: 50
Postby kkelly3201 » Tue Sep 08, 2009 9:05 pm
Ok good.
kkelly3201
Postby gt4rcdude » Thu Sep 10, 2009 2:41 pm
From what I can recall, both the anti-lag and the heat exchanger sprayers are not functional on the ST205WRC's from the factory.
gt4rcdude
Postby kkelly3201 » Thu Sep 10, 2009 8:26 pm
Well I don't believe I own a WRC, but I thought that was the higher-end model, why would it's parts not be functional?
kkelly3201
Postby Corey » Thu Sep 10, 2009 8:42 pm
The anti-lag would likely destroy the turbo in quick order if it was functional.
Corey
Images: 50
Postby Sal » Tue Oct 06, 2009 10:21 pm
Do you mean Water Injection?
It comes with the reservoir and sprayer but other then that, you will need to go out of your way to get it to work.
'94 ST205 GT-FOUR WRC
13.3 @ 101MPH
Sal
Postby lumbercis » Tue Oct 06, 2009 10:50 pm
Water to Air intercooler: Yes
Anti-lag: No
Water Injection: No?
The non-functional parts exist for homologation purposes (so they could be used on the Rally car)
Caldina powered...
lumbercis
Postby Corey » Tue Oct 06, 2009 11:33 pm
The 205WRC models (2500) came with functional, but disabled Waterinjection pumps.
See photos and info on www.gtfour.co.uk -> what is -> 205WRC
Corey
Images: 50
Postby timmey » Sat Oct 24, 2009 7:32 pm
So why put it in?
Timmey
timmey
Postby zero06 » Sat Oct 24, 2009 7:42 pm
they put it in soo they could use the systems in the races. wrc rules required the manufacturer to make X amount of cars sold with the same systems. if toyota didnt comply they wouldent be able to use the systems in their rally car.
soo why arent they enabled? well anti lag and water injection dont make for a good dependable consumer car.
zero06
Re: ST205 Water-to-Air Intercooler functional from factory?
Postby tubasteve » Wed Feb 08, 2012 3:54 am
Looks like a cold start injector on the other models....
tubasteve
Postby CMS-GT4 » Sun Sep 08, 2013 6:49 pm
So can the 185 cold start injector be used on a regular 205 engine to adapt for water injection?
Postby 801Alltrac » Sun Sep 08, 2013 10:29 pm
CMS-GT4 wrote:So can the 185 cold start injector be used on a regular 205 engine to adapt for water injection?
I like your thinkn CMS
801Alltrac
Images: 13
Return to FAQ / Archive
