ST205 Water-to-Air Intercooler functional from factory?
Re: ST205 Water-to-Air Intercooler functional from factory?
Postby ___Scott___ » Mon Sep 09, 2013 3:38 am
A cold start injector will work for water injection. That thing mounted in the top of the intercooler is cold start injector from (I think) an '89 Camry. I won't claim it's an optimal arrangement, but it worked. It is nice to get a solenoid valve and sprayer nozzle in one unit.
I used a peak-and-hold style injector driver circuit to drive the CSI, but it's probably not necessary. The solenoid in the CSI would just run hotter when you are injecting water.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Postby CMS-GT4 » Mon Sep 09, 2013 2:09 pm
That sounds great. As long as that hole exists on my st205 engine, then I will just pop a cold start injector in there and make my own WI instead of having to drill holes.
Postby YerRandO » Mon Sep 09, 2013 3:33 pm
CMS-GT4 wrote:That sounds great. As long as that hole exists on my st205 engine, then I will just pop a cold start injector in there and make my own WI instead of having to drill holes.
Doesn't look like it does on a standard ST205 manifold
The St205 WRC manifold is shown here with it: http://www.gtfours.co.uk/pics/intake_man/205/manifold.htm
-James
YerRandO
Return to FAQ / Archive
