Which OEM oil filter are you guys using (2nd gen motors)?
Postby four twenty » Thu Jan 06, 2005 10:22 pm
I accidentally found out that the ST165 oil filter (08922-02011) fits better than the ST185 oil filter for 2nd gen. engines with 3" downpipes. Previously, I found myself putting a notch (or dent) in the 185 filter to make it clear the downpipe. With the 165 filter, clearance is not an issue. Has anyone else noticed this? Also is there anything wrong with using a 1st gen. filter on a 2nd gen. motor? So far everything seems to be allright.
Brent
1989 ST165
Hermosa Beach, CA
four twenty
Postby Gary » Thu Jan 06, 2005 11:03 pm
I'm using the 90915-YZZA1, the same one for 7th gen Celica.
It's kind of PITA putting it on and removing it, but it's doable.
Never thought that ST165 one is smaller. :shrug:
93 ST185
Gary
Postby alltracman78 » Sun Jan 09, 2005 12:47 pm
Less oil flow? :shrug:
I've got a Aussie dp, use a 185 filter, and have no clearance problems...
Postby RIalltrac » Sun Jan 09, 2005 4:13 pm
I've also got the 3" aussie pipe, I use the mobil1 filter for the 185. fits fine for me.
Chris - 90 ST185
RIalltrac
Images: 2
Postby alltracman78 » Sun Jan 09, 2005 10:29 pm
Chris, Toyota one is cheaper. :wink:
Postby RIalltrac » Sun Jan 09, 2005 10:45 pm
ya but i'll tell ya what, I've never seen cleaner oil between changes. Like I can pull my dipstick out right now and it will be near the same color it was when I put it in. I'm so used to seeing black ooky looking oil from using fram filters and similar filters. They might cost a couple extra bucks, but they're always available and the autoparts store is about 15 minutes closer than the nearest toyota dealership, my laziness has a price.
Chris - 90 ST185
RIalltrac
Images: 2
Postby Gary » Sun Jan 09, 2005 10:57 pm
Chris, nice sig...
93 ST185
Gary
Postby alltracman78 » Sun Jan 09, 2005 11:12 pm
I went from Bosch to Mobil 1 to Toyota. My color never changed :shrug:
It's always been black within the first 1000m. Guess I give the cars too much hell :D
Return to FAQ / Archive
