ST165 and ST185 Interchangeable parts
Postby Alltrac-ST165 » Mon Nov 09, 2009 4:53 am
Hey guys...I was looking at all the stickys but was unable to find a thread about the 165 and 185..I have a friend who's 185 just went down...and wants to sell me some parts...But I dont know what will fit..IF anyone knows some interchangeable parts...Please let me know!
THANKS!
Alltrac-ST165
Postby Rick89GTS » Mon Nov 09, 2009 6:29 am
List the parts and we can let you know.
Rick89GTS
Postby Alltrac-ST165 » Mon Nov 09, 2009 9:01 am
Rick89GTS wrote:List the parts and we can let you know.
Exhaust
Suspension
TMIC
ECU
Thanks
Alltrac-ST165
Postby Rick89GTS » Mon Nov 09, 2009 8:19 pm
The 185 exhaust will bolt up to the 165 but the muffler outlet pipe may be a bit close to the rear tow hook. A minor adjustment may be required.
I know the 185 fronts struts are not swappable.
The ATA TMIC will not bolt up to the 165 and you wouldn't want that anyways. You'll heat soak without some major mods.
Some guys have run swapped 185 motors in their 165s with the 165 ECU without problems, but that is with extensive rewiring. For your situation, no, you don't want the 185 ECU for your stock 165.
I'm sure some of the others will chime in with their expertise.
Rick89GTS
Return to FAQ / Archive
